Set of points on the complex plane
cbarker1
MHB
Dear Everybody, I am wanting to check the solution to this question:
Sketch the set of points determined by the given conditions:
a.) $\left| z-1+i \right|=1$
b.)$\left| z+i \right|\le3$
c.)$\left| z-4i \right|\ge4$
work:
I know (a.) is a circle with radius 1 and its center at (-1,1) on the complex plane see in figure 1.
I know (b.) is a circle with radius 3 and its center at (0,1) on the complex plane see in figure 2.
I know (c.) is a circle (?) with radius 4 with its center (0,-4) on the complex plane see in figure 3.
Thanks
Cbarker1
  • Hand-drawn complex plane with horizontal Re axis and vertical Im axis; a small circle sits in the second quadrant, tangent to the Re axis, with its centre marked 2 and a radius segment labelled 1.
  • Hand-drawn complex plane with horizontal Re axis and vertical Im axis, showing a circle centred at a point labelled 1 on the real axis's upper side, with radius 3 marked by a segment to the right.
  • Hand-drawn complex plane with horizontal Re axis and vertical Im axis, an orange circle centred below the origin, a dot labelled -4i at the centre and a red radius labelled 4.
Almost. But "=", "[tex]\le[/tex]", and "[tex]\ge[/tex]" are not the same! In general, |z- a| is the distance from complex number z to complex number a. Yes, the set of points, z, in the complex plane, such that |z- 1+ i|= |z- (1- i)|= 1 is the circle with center at 1- i, (1, -1), and radius 1. Similarly, |z+ i|= 3 is the circle with center at i, (0, 1), and radius 3. But your problem has [tex]\le[/tex] rather than =. In addition to the circle where the distance is equal to 3, this set contains also the interior of the circle, the "disk" with center at i and radius 3.
Likewise, (c) is the circle with center 4i, (0, 4), and all points outside that circle.
