SHM Question: What is the maximum extension of the spring?
The maximum extension of a spring attached to a 50g block with a stiffness constant of 9 N/m can be determined using conservation of energy principles. The time taken for the block to reach the lowest point is calculated using the formula T = 2π√(m/k), resulting in approximately 0.23 seconds. The correct approach to find the maximum extension involves considering both kinetic and potential energy, specifically incorporating the potential energy of the spring (Usp = 1/2 k x²) alongside gravitational potential energy (Usp = mgh).
  • Understanding of Hooke's Law and spring constants
  • Familiarity with basic mechanics and energy conservation
  • Knowledge of oscillatory motion and period calculation
  • Ability to manipulate equations involving kinetic and potential energy
  • Study the conservation of mechanical energy in spring systems
  • Learn about the potential energy of springs (Usp = 1/2 k x²)
  • Explore the dynamics of harmonic motion and its equations
  • Investigate the effects of mass and spring constant on oscillation periods
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators seeking to clarify concepts related to springs and energy conservation.
Alex Cooper
A 50g block is attached to a vertical spring whose stiffness constant is 9N/m. The block is released at the position where the spring is unextended. What is the maximum extension of the spring? How long does it take the block to reach the lowest point?
Fsp=-kx
T=2pi(sqrtm/k)
KE=1/2mv^2
Usp = mgh
I found the time it took to reach the lowest point but cannot seem to find the first portion of the question
Here is what I did for the time it took to reach the lowest point
T=2pi(sqrtm/k)
=2pi(sqrt0.05/9)
=0.468s/2
=0.23s
Hello Alex, Welcome to Physics Forums.
T=2pi(sqrtm/k)
=2pi(sqrt0.05/9)
=0.468s/2
=0.23s
You should be a bit more careful with your notation. When you introduced dividing by two in the second to last line, the quantity is no longer equal to the quantity above. You should also indicate the logic behind what you're doing with a comment.
That said, the division by two is not correct here. It's not a half cycle from the equilibrium point to an extreme. A half cycle would be a trip from equilibrium to extreme and then back to the equilibrium point (the block would then continue through the equilibrium point and continue upwards to a higher extreme point, then return to the equilibrium point to complete a full cycle). So choose another value other than "2".
For the distance to the lower extreme, consider a conservation of energy approach. Your Relevant equations did not include the potential energy for a spring, but you should have that in your text or notes.
  • · Replies 16 ·
10K
