Shortcuts to find a solution to a double integral
2 replies · 1K views · last reply
Amaelle
Let T be the triangle of vertices (0,0),(2,2),(-4,0) . compute the integral ∫∫xydxdy over the region T
0<=y<=(x+4)/3
-4<=x<=2
I know the value of this integral is equal to 0, but I would like to see if there is any tricks to spot this answer using symmetries or even odd propreties?
Thanks in advance
This isn't a trick but I thought I'd just point out that the boundaries that you gave aren't right (i.e. yours is for a right angled triangle); you need to split the region of integration into ##0 \leq y \leq \frac{x+4}{3}##, ##-4 \leq x \leq 0## as well as ##x \leq y \leq \frac{x+4}{3}##, ##0 \leq x \leq 2##.
yes thanks a lot , you are right the point is that I used a big a triangle with the following boundaries ( and calculated the integral over it) and then substructed the inetgral over a s smaller integral with the following boundaries
0<x<2 and 0<y<x
