Shortest Distance Homework: Find Origin to Curve x^2+2xy+y^2=150
  • Thread starter Thread starter Air
    Shortest distance
The discussion focuses on finding the shortest distance from the origin to the curve defined by the equation x² + 2xy + y² = 150. The method involves using Lagrange multipliers to minimize the distance squared function f(x,y) = x² + y² under the given constraint. The solution reveals two points, (\sqrt{150}/2, \sqrt{150}/2) and (-\sqrt{150}/2, -\sqrt{150}/2), both equidistant from the origin. The final step is to compute the distance to confirm the shortest distance is the same for both points.
  • Understanding of Lagrange multipliers for optimization
  • Knowledge of partial differentiation techniques
  • Familiarity with distance formulas in Cartesian coordinates
  • Ability to manipulate and solve algebraic equations
  • Study the application of Lagrange multipliers in constrained optimization problems
  • Learn about partial derivatives and their role in finding extrema
  • Explore distance minimization techniques in multivariable calculus
  • Practice solving similar problems involving curves and distances
Students studying calculus, particularly those focusing on optimization problems, as well as educators looking for examples of applying Lagrange multipliers in real-world scenarios.
Air
Find the shortest distance from the origin to the curve x^2+2xy+y^2=150.
\frac{\partial f}{\partial x}, \frac{\partial f}{\partial y}
3. The problem I'm occurring
I'm not sure how to start is thus can't attempt it. I would have used the Lagrange theory but that would give the max point and I also don't have the constraint so cannot use it. For a start, can someone suggest how I would start. Any methods? I have to use partial differentiation.
You can use Lagrange's multiplier method to find maxima as well as minima. Apply it to the distance squared function f(x,y)=x^2+y^2 with the constraint x^2+2xy+y^2=150.
I have reached a point of confusion...
f(x,y) = x^2+y^2
g(x,y) = x^2+2xy+y^2=150
\mathrm{Equation 1: }2x - \lambda (2x + 2y) = 0 \implies \lambda = \frac{2x}{2x+2y}
\mathrm{Equation 2: }2y - \lambda (2x + 2y) = 0 \rightarrow 2y - \left( \frac{2x}{2x+2y}\right) (2x + 2y ) = 0 \rightarrow 2x+2y = 0 \implies y=x
Into constraint equation to solve for value of x and y.
\therefore y^2 + 2y^2 y^2 = 150 \implies y = \pm \sqrt{\frac{150}{4}} = x
Which gives many solutions. How can I saw which is the shortest distance?
Well, you got two solutions: (\sqrt{150}/2,\sqrt{150}/2) and (-\sqrt{150}/2,-\sqrt{150}/2). Both have the same distance from the origin, compute it and you have the answer.
  • · Replies 18 ·
