Should point at which E field = 0 coincide with V = 0?
  • Thread starter Thread starter David Day
    Field Point
6 replies · 2K views
David Day
A problem I solved asks this:
There is a point charge of 3q at the origin and another charge of -2q at x = 5. At what value of x relative to the origin is the electric field equal to zero?
So:
E = E1 + E2
0 = E1 + E2
E1 = -E2
kQ1/x2 = -kQ2/(5-x)2
Solving for x, the point at which these fields cancel out is x ≈ 2.75.
At the start of this problem I had mistakenly solved for the point at which the electric potential equals zero:
V = V1 + V2
0 = V1 + V2
V1 = -V2
kQ1/x = -kQ2/(5-x)
Solving for x yields a clean x = 3.00.
Are my calculations correct, or should these points coincide? At a point in which the total electric field equals zero, shouldn't the total voltage be zero as well?
[Thread moved to homework forum by moderator]
hi,
if you look at the relationship between potential and electric field strength (or at the dimensions), you see that E = 0 if ΔV = 0 for a (small) change in position...
One more thing is that V is only established up to a constant. We usually choose that to have V = 0 at infinity, but that is just a convention.
There's two points on the x-axis where the electric field is zero (if not including the "point" at ##x\rightarrow\pm\infty##), and neither of them is between the charges when ##Q_1## and ##Q_2## are of different sign as in this problem.
Ask your self the following question in 1-dimension. If a function of x is zero at a certain value of x, is its slope equal to zero at the same value of x?
Just to clarify, the OP's question is why isn't V zero where E is zero, so the directly analogous question in 1D is the reverse of the above: why isn't the value of the function zero where its slope is zero?
Further to the above replies, there is nothing special about a point where V is zero. Potentials are always relative. You can define any point to be at V=0; the potential at any other point is relative to that.
In many electrostatics questions it is common to define the potential at infinity to be zero, but it is only a convention.
As against that, E=0 does have significance.
That really flicked a switch in my head. Thanks for that!
