Show function series involving arctan is not differentiable at x=0
schniefen
178
Show ##f(x)=\sum_{k=1}^\infty \frac{\arctan (kx)}{k^2}## is not differentiable at ##x=0##.
Unsure.
I have previously shown that the function series is differentiable at ##x\neq 0##. The series converges uniformly (thus pointwise) on ##\mathbb R## and the term wise differentiated series is uniformly convergent on any interval ##d\leq |x|##, where ##d>0##. Moreover, the terms are continuously differentiable. So from all that, we can conclude that ##f(x)## is differentiable on ##\mathbb{R}\setminus \{0\}##, however, I am unsure how to show it is not differentiable at ##x=0##. How would you do that?
schniefen said:
Homework Statement: Show ##f(x)=\sum_{k=1}^\infty \frac{\arctan (kx)}{k^2}## is not differentiable at ##x=0##.
Relevant Equations: Unsure.
You could investigate the expression ##\sum_{k=1}^\infty \frac{\arctan(kh) - \arctan(0)}{hk^2}## for small ##h##. If the function is differentiable, then the limit of that expression must be finite as ##h \rightarrow 0##. Perhaps you could find a sequence of ##h_n## where the expression is unbounded? Just an idea.
Likes schniefen
Can you use the series expansion of ##\arctan(kx)=\displaystyle{\sum_{j=0}^\infty (-1)^j\dfrac{(kx)^{2j+1}}{2j+1}}##?
Likes schniefen
Definitely.
We know that [itex]f(0) = 0[/itex], so it suffices to show that [tex]
\lim_{x \to 0} \frac{f(x)}{x} = \lim_{x \to 0} \lim_{K \to \infty} \sum_{k = 1}^{K} \frac{\arctan(kx)}{kx} \frac 1k[/tex] does not exist.
That [itex]\lim_{y \to 0} \frac{y}{\tan(y)} = 1[/itex] might be useful.
Likes nuuskur, fresh_42, schniefen and 1 other person
Can we exchange those limits? That is, does ##\lim_{x \to 0} \lim_{K \to \infty}\ldots=\lim_{K \to \infty} \lim_{x \to 0}\ldots##?
I assume you would have to justify that!
This is the point that is left to show. If you use the series expansion that I have mentioned, then you run into the same problem: can we exchange the two series? I would approach it with an indirect proof. Assume the limit exists, because if it does not, then exchanging the limits is impossible - they do not exist.
Another idea that I first had: fix a point ##x=\varepsilon ## near ##x=0## and show that the series diverges but I'm not sure it does.
I assume you need to be rigorous here. Otherwise, you could just take:
$$f'_K(x) = \sum_{k = 1}^K \frac 1 {k^2(1 + k^2x^2)}$$$$f'_K(0) = \sum_{k = 1}^K \frac 1 {k^2}$$$$f'(0) = \lim_{K \to \infty}f'_K(0) = \frac{\pi^2}{6}$$And, unless you are being rigorous, how do you know whether that's correct or not?
The statement that a limit function ##f## of a sequence ##(f_n)_1^\infty## (of continuous functions) is continuous at a point ##a## means that ##\lim_{x\to a} f(x)=f(a)##, i.e.
##\lim_{x\to a}(\lim_{n \to \infty}f_n(x))=\lim_{n \to \infty}(\lim_{x\to a} f_n(x)).##​
This exchange is permitted when the convergence is uniform. In this case, ##a=0## and
##f_n(x)= \sum_{k = 1}^{n} \frac{\arctan(kx)}{kx} \frac1k .##
So I guess I need to
  1. Check the uniform convergence of ##f_n(x)##.​
  2. Check that ##f_n## and ##f## are continuous at ##x=0##.​
It looks to me like ##f_n(x)## isn't even defined at ##x=0##, so how can it be continuous there?
Where's the derivative here? For the derivative you are dealing with points that are explicity not ##0##.
Likes schniefen
You are right! I forgot. So ##x\neq 0##.
That said, I'm still unsure what exactly it is I need to check in order for the exchange of limits to be valid.
Okay, you seem all at sea here, IMO. So. We're trying to prove that a function is NOT differentiable. In this case at ##x = 0##. In general, this means we have to show that the following limit does NOT exist:
$$\lim_{h \to 0}\frac{f(0 + h) - f(0)}{h}$$In this case ##f(0) = 0##, so the limit becomes:$$\lim_{h \to 0}\frac{f(h)}{h}$$How do you, in general, show that a limit does not exist? That depends to some extent on what you think goes wrong: do the limiting values oscillate or become unbounded? In any case, one approach is to find a sequence (in this case ##h_n \to 0##) where ##\frac{f(h_n)}{h_n}## does not converge to a single limit. This is the idea that both @pasmith and I had. Note that it's sufficient to find one such sequence.
Now, let's look at the specific function you have. The function values for our sequence will be:
$$\frac{f(h)}{h} = \sum_{k = 1}^{\infty}\frac{\arctan(kh)}{hk^2}$$We could proceed with ##\arctan## as it is or we could use the Taylor series, as suggested above. My instinct would be to try as it is first. And, try to make that infinite series become unbounded. That might not work. That would be one approach.
For example, if you could find a sequence ##h_n## where
$$\forall n: \frac{f(h_n)}{h_n} > n$$Then you would be done. The limit couldn't then be finite and the function would have been shown to be non-differentiable at ##0##
Likes schniefen
PS I have a solution using the above method, this hint and a well-known divergent series!
Another approach is proof by contradiction: Assume that [itex]f'(0)[/itex] exists and see what follows.
Ok, thanks for clarifying things @PeroK. I had to remind myself of the sequential characterization of the limit and the aim is clear now.
Have you been able to find a sequence such that $$\forall n: \frac{f(h_n)}{h_n} > n?$$
Yes. Following the hints in post #14.
Ok, I think I also may have a solution. Grateful for any feedback.
Take ##h_k=1/k^2##, then we have ##h_k\to 0## as ##n\to\infty##. Also, $$\frac{f(h_k)}{h_k}=\sum_{k=1}^\infty \arctan (1/k).$$ This series diverges according to the limit comparison test with ##1/k##, i.e. we have $$0<\lim_{k\to\infty}\frac{\arctan(1/k)}{1/k}=1<\infty.$$ So, we have found a sequence that converges to zero (and is nowhere zero), but for which ##\lim_{k\to\infty}\frac{f(h_k)}{h_k}## does not exist.
Take ##h_k=1/k^2##,
##k## is a dummy variable within the summation. ##h## can't vary with each term in the sum.
We'll always have uniform convergence of $$\sum_{k = 1}^{\infty}\frac{\arctan(kh)}{hk^2}$$ no matter how we fix ##h##, be it as ##h_n=1/n## or some other sequence tending to ##0## as ##n\to\infty##.
This is irrelevant. If you have ##f(x) = \sum_{k = 1}^{\infty} a_k(x)##, you can't set ##x = k##. In that case, ##f(k)## makes no sense.
Hmm, I'm confused. Are you claiming there is a sequence ##(h_n)_1^\infty## (independent of ##k##) such that $$\sum_{k = 1}^{\infty}\frac{\arctan(kh_n)}{h_nk^2}$$ diverges? I don't see how that would be possible.
schniefen said:
Hmm, I'm confused.
I see that.
##k## is a dummy variable. What you are trying to do makes no sense.
Nevertheless, we can find ##h_1 > 0## with$$\sum_{k = 1}^{\infty}\frac{\arctan(kh_1)}{h_1k^2} > 1$$And ##h_1 > h_2 > 0## with $$\sum_{k = 1}^{\infty}\frac{\arctan(kh_2)}{h_2k^2} > 2$$Etc.
Given the nature of the function, that's the only way that ##f## can fail to be differentiable at ##x = 0##.
It might be worth posting this proof, at least in outline, to let us see how much rigorous maths you understand.
PS it's getting late in the UK, so I'm signing off for today.
If [tex]
f_K(x) = \sum_{k=1}^K \frac{\arctan(kx)}{k^2}[/tex] then the series expansion [tex]
f_K(x) = \sum_{k=1}^K \sum_{n=0}^\infty \frac{(-1)^nk^{2n-1}x^{2n+1}}{2n+1}[/tex] is only valid for [tex]x\in \bigcap_{k=1}^K \{t \in \mathbb{C} : k|t| < 1\} = \{ t \in \mathbb{C}: |t| < K^{-1}\}[/tex] so that the radius of convergence tends to zero as [itex]K \to \infty[/itex].
pasmith said:
If [tex]
I thought about fixing a point near zero and assuming differentiability so that
f(\varepsilon )=L\varepsilon +o(\varepsilon )= \sum_{k=1}^\infty \sum_{n=0}^\infty \frac{(-1)^nk^{2n-1}\varepsilon ^{2n+1}}{2n+1}
and then compare the coefficients at ##\varepsilon^n.## This would result in ##L=\displaystyle{\sum_{k=1}^\infty \dfrac{1}{k}}## which is divergent. But it feels a bit like cheating, i.e. I'm not sure whether this is rigorous.
Related to Show function series involving arctan is not differentiable at x=0
1. What is a show function series involving arctan?
A show function series involving arctan is a mathematical series that involves the arctangent function, which is the inverse of the tangent function. This series is often used to approximate complex functions and can be written as a sum of terms involving arctan.
2. Why is the show function series involving arctan not differentiable at x=0?
The show function series involving arctan is not differentiable at x=0 because the arctangent function is not differentiable at that point. This is because the derivative of the arctangent function approaches infinity as x approaches 0, making it undefined at that point.
3. Can the show function series involving arctan be made differentiable at x=0?
No, the show function series involving arctan cannot be made differentiable at x=0. This is because the arctangent function itself is not differentiable at that point, so any series involving it will also not be differentiable at that point.
4. How is the show function series involving arctan used in science?
The show function series involving arctan is commonly used in science to approximate complex functions and make calculations easier. It is also used in fields such as physics and engineering to model and analyze various systems and phenomena.
5. Are there any other points where the show function series involving arctan is not differentiable?
Yes, there are other points where the show function series involving arctan is not differentiable. These points occur whenever the arctangent function is not differentiable, which includes all points where the tangent function has a vertical asymptote. These points can be found by solving for x in the equation tan(x) = infinity.
