MHB Show that is the square of an integer
  • Thread starter Thread starter Joppy
    Integer Square
The discussion centers around a mathematical problem involving positive integers \(a\) and \(b\) where \(ab + 1\) divides \(a^2 + b^2\). Participants express their interest in the problem, noting its complexity and connection to the 1988 International Mathematical Olympiad. There is a debate about the generality of the solutions presented, with some participants questioning whether the identified solutions are exhaustive. The conversation highlights the challenge of proving the completeness of the solutions. Overall, the problem is recognized as intriguing and layered, prompting further exploration.
Joppy
MHB
I couldn't find this problem anywhere else on the forum so I thought I'd post it. If however, I am duplicating, mods feel free to remove the post :p.
No doubt many of you know it already, but I found it quite interesting.
Let $a$ and $b$ be positive integers such that $ab + 1$ divides $a^2 + b^2$. Show that $\frac{a^2 + b^2}{ab + 1}$ is the square of an integer.
Mathematics news on Phys.org
Let $a$ and $b$ be positive integers such that $ab + 1$ divides $a^2 + b^2$. Show that $\frac{a^2 + b^2}{ab + 1}$ is the square or an integer.
This one's infuriating. I love it!
-Dan
-Dan
So many layers!
my solution:
if $a=b^3$
then $\dfrac {a^2+b^2}{ab+1}=\dfrac {b^6+b^2}{b^4+1}=b^2$
if $b=a^3$
then $\dfrac {a^2+b^2}{ab+1}=\dfrac {a^2+a^6}{a^4+1}=a^2$
$\therefore ab+1$ divides $a^2+b^2$ we may set $a=b^3,or\,\, b=a^3$
(here $a,b \in N$)
This is problem #3 day 2 of the 1988 IMO.
Thought it was no. 6.
Albert said:
my solution:
if $a=b^3$
if $b=a^3$
(here $a,b \in N$)
How do we know that this is the most general solution (or that others don't exist)? I can't think of how to prove that one way or another.
-Dan
-Dan
I think Albert has stumbled upon one set of solutions, but there are many more in similar forms.. But! I'll have to check myself first when I get a chance.
-Dan
since we are given :$a^2+b^2 $ is a multiple of $ab+1$
we must find the relation between $a$ and $b$ as my example $a=b^3$ or $b=a^3$
may be we can find different link between $a,b$ and check the result
the following steps will help us finding other solutions:
if $a>b$
take $\dfrac {a^2+b^2}{ab+1}=2^2=4=k^2----(*)$ for instance
(1) set $a=b^3$,we get $a=8,b=2$
(2) put $b=8 $ to $(*)$ we get $a=2$ ,or $a=30$ another solution $ (a,b)=(30,8) $ is found
(3) put $b=30$ to $(*)$ we get $a=8$ or $a=112$ again $(a,b)=(112,30)$ is found
(4) put $b=112 $ to $(*)$ we get $a=30$ ,or $a=418$ another solution $ (a,b)=(418,112) $ is found
continue these steps until no other solution found then next $k$
if $a>b$
The general solutions of :$\dfrac {a^2+b^2}{ab+1}=k^2-----(*)\,\,\,(a,b,k\in N)$
because of symmetry we let $a>b$
from previous solution we have $ b=k,a=b^3=k^3 $
put $b=k^3$ to $(*)$
we find another solution of $a$
$\dfrac {a^2+k^6}{ak^3+1}=k^2$
$\rightarrow a^2-ak^5+k^6-k^2=0$
$a=k,\,\, or \,\ ,a=k^5 - k$
Albert,
you are digressing
you are finding general solution instead of proving that it is perfect square
kaliprasad said:
Albert,
you are digressing
may be a little bit digressing,but from this I can deduce that it is perfect square:
$let :\dfrac{a^2+b^2}{ab+1}=y\\
a^2-yab+b^2-y=0\\
a=\dfrac{yb\pm\sqrt{y^2b^2-4b^2+4y}}{2}$
since $a,b\in N$
$y^2b^2-4b^2+4y$ must be perfect square
this can only be done with $b=y\sqrt y=k^3$
$a=\dfrac {y^2\sqrt y \pm (y^2\sqrt y-2\sqrt y)}{2}=y^2\sqrt y-\sqrt y =k^5-k\,\, or \,\, a=\sqrt y=k$
as given from general solution
here $(y=k^2)$ must be perfect square
a^2-yab+b^2-y=0\\
since $a,b\in N$
This is a mixup between arithmetic and algebra. for example $b^2+5$ is not a perfect square in algebra but is it in arthmetic when $b=2$ as $2^2+5= 3^2$
note $a,b\in N$ and $ab+1$ divides $a^2+b^2$
$y^2b^2-4b^2+4y=(yb-2\sqrt y)^2$ is perfect square
this implies $b=y\sqrt y \in N$
$\therefore y$ must be perfect square
so $y=k^2, b=k^3$
