Show that Linear Combination is not Hermitian
11 replies · 13K views
Ryomega
Show that linear combinations A-iB and A+iB are not hermitian if A and B (B≠0) are Hermitian operators
Hermitian if: A*=A
Hermitian if: < A l C l B > = < B l C l A >
So I've seen this question everywhere but not the solution to it.
I get that the solution isn't (A+iB)* = (A*+i*B*) = (A*-iB*) (since i*=-i)
So that's not helping me prove all its non-hermitianess, but it doesn't seem right since if I changed the order of the Hermitian:
< +iB l C l A > ≠ < A l C* l -iB >
Is that where I should be going with this? Or am I completely going wrong?
I know it's against the rules, but could someone show me the solution? I've been stuck on this for an entire day now and I'm fed up.
Thanks a lot!
Your brackets don't look like the way I was taught Dirac notation. The operators go in the middle, not on the left or on the right.
Consider two states, [itex]\psi, \phi[/itex]. An operator [itex]\hat S[/itex] is Hermitian if
[itex]\langle \psi | \hat S | \phi \rangle = \langle \phi | \hat S | \psi \rangle[/itex]
Knowing that [itex]\hat A, \hat B[/itex] are Hermitian, plug in [itex]\hat A \pm i \hat B[/itex] for [itex]\hat S[/itex] above.
Hi, sorry I'm fairly new to this notation thing. After reading it a thousand times I think I got it. Rest assured, I think I have learned Dirac notation as you have.
And thank you for the help. Integrating A - iB and A + iB makes them not equal to each other. Which now makes sense.
Thanks a lot!
Let me clarify a bit, as I wrote something that was a bit misleading. For any operator [itex]\hat C[/itex],
[tex]\langle \psi | \hat C | \phi \rangle = \langle \phi | \hat C^* | \psi \rangle[/tex]
And only for a Hermitian operator is [itex]\hat C^* = \hat C[/itex].
But really, this problem is done when you realize that, if [itex]\hat C = \hat A \pm i \hat B[/itex], then [itex]\hat C^* = \hat A \mp i \hat B[/itex].
This is going to sound idiotic... but what does the upside down +/- sign denote?
The top plus on the left goes with the top minus on the right; the bottom minus on the left goes with the bottom plus on the right. For example, when [itex]\hat C = \hat A + i \hat B[/itex], then [itex]\hat C^* = \hat A - i \hat B[/itex].
AHhhh! so it's just a thing I have to remember. Thank you!
That Ahh, isn't screaming in fear... it is in understanding in...understanding or (whatever word I was actually looking for)
Could you show how you do this part please. I'm assuming you integrate ∫ψ(A-iB)ψ*
but I am not sure where to begin on this and I feel I'm missing something very basic
A and iB are simply constants.
Integrating a constant just gives itself back. So you get A-iB and A+iB.
By definition A*= A if they are Hermitian.
Since they don't equal each other, they are not Hermitian.
ah. I was assuming A and B to be functions, and that was making things a lot more complex.
A and B are Operators. You can't just integrate over them. You should really pick up the book "Modern Quantum Mechanics" by Sakurai and read the first 30-50 pages.
There are two ways to introduce quantum mechanics. You either take the wave mechanics route, which leads to a very flawed understanding of quantum mechanics, or you learn it the way dirac introduced it.
Now, I don't know whether you americans really use the "*" to indicate that you mean the Operator which is dual to non-starred operator. In my opinion, that would be very misleading. We use a different symbol.
If you want to know what C* really is, then you first need to study these "states" a bit.
If you have ket (state) |a>, then that is a vector on some complex vector space.
The bra <a| is the bra dual to |a>, that means, its a vector on the complex vector space which is dual to the vector space of which |a> is element. These are properties introduced in linear algebra which you need to know in order to understand quantum mechanics.
If you progress to operators, you need to understand that C operator only acts on ket |a>, not on bra <a|. Only the operator dual to C - C* - can act on <a|.
Sakurai explains this in great detail.
In order to show your task, i would work from the fact that an operator is defined by the way it acts on a state. Thus, if you want to prove hermiticity, or the lack of, you should take a look at:
<a|C|a>
and show that it is (not) equal to
(<a|C|a>)*
Keep in mind that <a|b> = <b|a>* and that you can act as if C|a> was just a ket.
