Show that the equipotential lines are circles
The discussion focuses on the determination of equipotential lines in a given electrical potential field defined by the equation V(x,y,z) = A(2x² - 3y² - 3z²). The electrical field E is derived as E = 2A(-2x, 3y, 3z), and the work W₀ done on a test charge q₀ is expressed as W₀ = 2q₀Aa². The participants successfully demonstrate that the equipotential lines in planes parallel to the (yz)-plane are circles, with the radius calculated as r = √(1/3) when x = 1.0 m and V = 1000 volts, given q₀ = 1.0 microcoulomb and W₀ = 2.0 mJ.
  • Understanding of electrical potential and electric fields
  • Familiarity with the concept of equipotential lines
  • Knowledge of basic calculus and algebra for solving equations
  • Proficiency in manipulating equations of circles in a Cartesian coordinate system
  • Study the derivation of electric fields from potential functions
  • Learn about equipotential surfaces and their properties in electrostatics
  • Explore the mathematical representation of circles in standard form
  • Investigate the implications of work done by electric fields on test charges
Students and professionals in physics, electrical engineering, and applied mathematics, particularly those focusing on electrostatics and potential theory.
Erik P
In a specific area of the space, an electrical potential is given as:
\begin{equation}
V(x,y,z) = A(2x^2 - 3y^2 - 3z^2)
\end{equation}
where A is a constant.
a.) Determine the electrical field E for any given point in the area. A test charge q_0 is moved from the point (x,y,z)=(a,0,0) to origin (0,0,0). Determine the expression for the work W_0 performed on the test charge by the electrical force. Determine A as a function of W_0, q_0, and a.
b.) Show that the equipotential lines in planes parallel to the (yz)-plane are circles. Determine the radius of the equipotentiallines where x=a=1.0 m and V=1000 volts, for q_0 = 1.0 micro columb and W_0 = 2.0 mJ.
The radius of a circle displaced from origin to a point (h,k):
\begin{equation}
R^2 = (y - h)^2 + (z - k)^2
\end{equation}
General expression for a circle:
\begin{equation}
y^2 + z^2 +Cy + Dz + E = 0
\end{equation}
Voltage due to point charge (really not sure if this is the right one to use, i tried inserting numbers and it gives me the wrong result):
\begin{equation}
V = \frac{q_0}{4\pi\epsilon_0R}
\end{equation}
Solved the first part a.)
\begin{equation}
\vec{E} = 2A(-2x\vec{i} + 3y\vec{j} + 3z\vec{k})
\end{equation}
\begin{equation}
W_0 = 2q_0Aa^2
\end{equation}
Part b.) I'm not sure how to tackle, here is what I tried...
\begin{equation}
V = A(2x^2 - 3y^2 - 3z^2) = \frac{q_0}{4\pi\epsilon_0R}
\end{equation}
\begin{equation}
r = \frac{q_0}{A(2x^2 - 3y^2 - 3z^2)4\pi\epsilon_0}
\end{equation}
\begin{equation}
A = \frac{W_0}{2a^2q_0}
\end{equation}
\begin{equation}
r = \frac{2a^2q_0^2}{4W_0A(2x^2 - 3y^2 - 3z^2)\pi\epsilon_0}
\end{equation}
Inserting numbers:
\begin{equation}
r = 4.49
\end{equation}
the answer is supposed to be 0.6 m, so obviously I'm way off. I suspect it has to do, atleast in part with me using the voltage for a point charge. Not sure how to go about this. I also need to show that they are circle, but that's also a little over my head at the moment.
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
W_0 = 2q_0Aa^2
\end{equation}
\begin{equation}
\end{equation}
You are given the potential finction V(x,y,z). It is not the potential of a point charge. You need the curve in a plane parallel to the (y,z) plane. What do you know about x in that plane?
I'm not entirely sure to be honest.
What is x on the (y,z) plane?
zero? Sorry, not entirely following here.
yes.
And what is x on the blue plane, parallel with the (y,z) plane?
ehild said:
yes.
Five, I guess?
Erik P said:
Five, I guess?
yes. Read the problem, you are given that x=a=1.0 m and V=1000 volts. How the potential function looks like if x= 1.0 m?
\begin{equation}
V(1,y,z) = A(2 - 3y^2 - 3z^2)
\end{equation}
Erik P said:
\begin{equation}
\end{equation}
oooohhhh.. i think i see it, give me a few mins to look at it
You want the line where V=1000 V. What is its equation?
\begin{equation}
1000 = A(2 - 3y^2 - 3z^2)
\end{equation}
\begin{equation}
0 = A(2 - 3y^2 - 3z^2) - 1000
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
0 = \frac{W_0}{2a^2q_0}(2 - 3y^2 - 3z^2) - 1000
\end{equation}
Erik P said:
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
\begin{equation}
\end{equation}
Can you bring it to the standard from of a circle? Where is the center? What is the radius? You also know that a=1. ( x=a=1.0 m) Wo and qo are also given.
\begin{equation}
0 = y^2 + z^2 + \frac{2000a^2q_0}{3W_0}-\frac{2}{3} \Rightarrow 0 = y^2 + z^2 - \frac{1}{3}
\end{equation}
Then r should be sqrt(1/3), right? with a center in (0,0)
Erik P said:
\begin{equation}
\end{equation}
Yes. Good work!
ehild said:
Yes. Good work!
Thank you for the help and also for being patient with me :)
You are welcome :oldsmile:
  • · Replies 23 ·
