Show that the given function maps the open unit disk into the upper half plane
The discussion focuses on demonstrating that the function w = f(z) = i((1-z)/(1+z)) maps the open unit disk into the upper half-plane and the unit circle to the real line. Participants express confusion about the mathematical notation and seek clarification on how to approach the problem. A hint is provided to use the formula for the imaginary part of w, which participants find cryptic. Suggestions include substituting z with a polar representation and analyzing the resulting imaginary component to confirm that it remains positive for z within the open unit disk. The conversation emphasizes the need for a clearer understanding of complex variables to tackle the problem effectively.
Raziel2701
4. Let w = f(z) = i(\frac{1-z}{1+z}). Show that f maps the open unit disk {z \in C | z < 1} into the upper half-plane {w\in C|Im(w) >0}, and maps the unit circle {z\in C||z|=1} to the real line.
I was given this hint:
"set w=i(\frac{1-z}{1+z}) and use the formula Im(w)= \frac{1}{2i}(w -\bar{w})"
This is cliche but, what does this mean in English? I've been trying to decipher some of this stuff, in order for me to know what to do, I must first understand what I'm being asked to do, so that would be my first request.
The second thought I have of this is that the hint given also doesn't mean much to me. So what exactly would be the topic I could read on to help me get more information on this concept I'm being tested on? I'm at a library right now, so if I were to pick up a book on complex variables, what topic more or less is this problem covering?
I need to be pushed on the right direction to solve this problem, right now I'm just more or less in the dark. The set notation is a bit cryptic for me. I get that z is an element of the set of complex numbers, but what exactly is it being said after the "|"?
Thanks!
And pardon the rough formatting.
Is it sufficient to show that since for the open disk z < 1, then if I plug a value less than one into w I get a result that is less than one and imaginary, and thus, it maps any point of the open disk into the upper half plane?
The same for the unit circle where |z| = 1. If I plug one I get zero for w, and thus I get the point (0,0) which is in the real line and therefore w maps any point on the unit circle to the real line?
So you have shown that the map w, maps boundaries to boundaries, now choose a z with |z|<1 and show that Im(w)>0, so perhaps write z=re^{i\theta} with r<1 and see if Im(w)>0.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
