Show the Cube root of x is uniform continuous on R.
The discussion focuses on proving that the function f(x) = x^(1/3) is uniformly continuous on the real numbers. The key approach involves analyzing the function separately for the intervals |x| ≤ 1 and |x| > 1, demonstrating uniform continuity on both segments. A critical point made is that for x and y in (1, ∞), the expression |x^(1/3) - y^(1/3)| can be bounded by |x - y|/3, confirming uniform continuity in that range. The proof also utilizes the compactness of the interval [-1, 1] to establish uniform continuity there. Overall, the method combines these findings to conclude that f(x) is uniformly continuous across the entire real line.
billy2908
Let f(x)=x^{1/3} show that it is uniform continuous on the Real metric space.
By def. of uniform continuity \forall\epsilon>0 \exists\delta&gt;0 s.t for \forall x,y\in\Re where |x-y|<\delta implies |f(x)-f(y)|< \epsilon
I started w/ |x^{1/3} -y^{1/3}|* (|x^{2/3} +xy^{1/3}+y^{2/3}|/|x^{2/3} +xy^{1/3}+y^{2/3}|)
=|x-y|/(|x^{2/3} +xy^{1/3}+y^{2/3}|)
But it doesn't seem to be uniform cont. if I set \delta=\epsilon*(|x^{2/3} +xy^{1/3}+y^{2/3}|)
Hint: Consider two cases separately: |x| ≤ 1 and |x| > 1. Then combine the results.
that's exactly how I wanted to prove it. By showing it is uniformly cont. on (-inf, -1) U (1, inf) and given it is uniformly cont. on [-1,1] since it's compact.
But even when I choose x,y say from (1,inf) I still get left off with d=e*(x^2/3 +(xy)^1/3 +y^2/3)
Which doesn't help to show uniform continuity. So far I only am familiar w/ the Lipgarbagez proof for Uniform continuity. i.e.
if |f(x)-f(y)|<M for some real M. then f is unif. cont.
I'm aware there's another type of unif. cont. maybe dealing w/ f(x)=x^1/3 but I have no experience in proving for those.
But x^(1/3) is Lipgarbagez on (1,inf) isn't it? It has a bounded derivative, right?
Sorry, can't use the def. of derivative yet at this point. Also even if I can, and the derivative is bounded on (1,inf) is unbounded as x-> 0 since it looks like a verticle line.
It's hardly 'verticle'. What the minimum value of (x^(2/3)+(xy)^(1/3)+y^(2/3)) for x and y in (1,inf)?
minimum value should be x=1, y=1 in (1,inf)
so (x^(2/3)+(xy)^(1/3)+y^(2/3))= 3.
But I don't know what you are trying to lead me to...
I want you to use that to show me that |x^(1/3)-y^(1/3)|<|x-y|/3 for x and y in (1,inf).
I think I got the proof, but want to make sure it's correct.
let z=(x^(2/3)+(xy)^(1/3)+y^(2/3)) then z>3 since x and y are in (1,inf)
=> 1/z <1/3
It actually works on (-inf, -1) as wellso again |x^1/3 - y^1/3| = |x-y|/z < d/3
So we can pick d=3*e.
Also since we know x^1/3 is cont. on [-1,1] which is compact. Then for all e>0 exist a d'>0 that works.
So then I just pick d=min{3e, d'}. Since I already showed it is uniform cont. on |x|>1.
would that suffice as a proof?
It looks ok to me.
  • · Replies 40 ·
  • · Replies 27 ·
