Showing a Sequence Also Satisfies the Fibonacci Sequence
  • Thread starter Thread starter Illania
    Sequence
To show that the sequence an = Arn satisfies the Fibonacci sequence, it is necessary to demonstrate that Arn = Arn-1 + Arn-2 for n > 2. By manipulating the equation r^2 = r + 1, one can derive that dividing both sides by r^(n-2) leads to the necessary relationship. This simplifies to r^n/r^(n-2) = r^(n-1)/r^(n-2) + 1, confirming that the Fibonacci condition holds. The key is recognizing that if r satisfies the quadratic equation, then the sequence defined by Arn will also satisfy the Fibonacci recurrence. Understanding the problem from multiple perspectives can aid in grasping the solution.
Illania
The problem:
Let r satisfy r2= r + 1. Show that the sequence an = Arn, where A is constant, satisfies the Fibonacci sequence an = an-1 + an-2 for n > 2.
The given equations above are the only relevant equations.
I think have to show that Arn = Arn-1 + Arn-2, but I'm not sure how to manipulate the given equations to achieve such a thing. I can factor one side so that Arn = A(rn-1 + rn-2), and then say that rn = rn-1 + n-2, but I have no idea what to do from here.
Illania said:
The problem:
Divide both sides by r^(n-2).
So, I'm guessing I can manipulate the exponents as you would normal ones, and dividing both sides by rn-2 would result in r2 = rn-1, correct?
No? What are r^n/r^(n-2), r^(n-1)/r^(n-2) and r^(n-2)/r^(n-2)??
rn/rn-2 = rn-1/rn-2 + 1, which simplifies to r2 = r + 1.
I'm still unsure of how this can be used to prove that Arn also satisfies the Fibonacci sequence.
EDIT: Does showing that the two set equal to each other simplifies to r2 = r + 1 prove that the two are equal? If so, why is that? This question really seems to be going right over my head.
It doesn't prove the two are equal. It proves that if r^2=r+1 then Ar^n=Ar^(n-1)+Ar^(n-2). All of your steps are reversible. Multiply both sides of r^2=r+1 by Ar^(n-2).
Thank you for the explanation! I was thinking in just one way rather than looking at the problem from multiple angles.
