Signal strength of a wave packet
The discussion revolves around the signal strength of a wave packet characterized by its frequency contributions. The original poster presents a mathematical formulation for the signal strength as a function of time and poses questions regarding the properties of the wave packet, including its graphical representation and the relationship between frequency and time intervals.
  • Participants explore the integral formulation for V(t) and question the limits of integration. There is also discussion about defining Δω and Δt in the context of the provided plots, with references to standard deviation and averaging over intensity.
The discussion is active, with participants clarifying mathematical details and engaging in back-and-forth regarding the integral limits and factors in the equations. Some guidance has been offered regarding the definitions of Δω and Δt, but there is no explicit consensus on these points yet.
Participants express uncertainty about the definitions of Δω and Δt, indicating a need for further clarification on these terms as they relate to the graphs and the overall problem context.
Elvis 123456789
Assume a wave packet is has contributions from various frequencies, give by g(ω)=C for |ω|<ω0, and g(ω) =0 for elsewhere.
a)What is the signal strength as a function of time, i.e., V(t)=?
b) Sketch g(ω) and V(t); You can use fooplots.com, for example, or python.
c) Indicate Δω and Δt in the above plots; Does the products of these two satisfy ΔωΔt>1/2?
V(t) = 1/√(2π) * integral from -∞ to +∞ of [ g(ω)*exp(iωt)] dω
exp(iωt) = cos(ωt) + isin(ωt)
a.) V(t) = 1/√(2π) * integral from -ω0 to +ω0 of [ C*exp(iωt)] dω
using eulers formula and the properties of even and odd functions
V(t) = 2/√(2π) * integral from 0 to +ω0 of [ C*cos(ωt)] dω
V(t) = 2C/√(2π) * sin(ω0t)/t = √(2/π)*ω0C * sin(ω0t)/ω0t
b.) the sketches for g(ω) and V(t) are in the attachments
c.) I am not really sure what Δω and Δt in these graphs
Shouldn't the lower integral limit be ##-\omega_0##?
Use the definition of standard deviation. For example for V(t), you will use
\Delta t = \sqrt{E[t^2]-(E[t])^2}
where ##E[\,\,]## means taking average over the intensity ##|V(t)|^2##. Similar arguments for ##g(\omega)##.
blue_leaf77 said:
Shouldn't the lower integral limit be −ω0−ω0-\omega_0?
I have a factor of 2 in the front to account for that. Is that not right?
Ah sorry I missed that, you are right.
  • · Replies 21 ·
10K
