SImpe question about square root function
45 replies · 8K views
Ali Asadullah
Is it a right mathematical operation (a*b)^0.5 = a^0.5 *b^0.5 when a and b either both are negative or one of them is negative.
Mathematics news on Phys.org
If a >= 0 and b >=0, [tex]\sqrt{ab} = \sqrt{a}\sqrt{b}[/tex]
If a <= 0 and b <=0, [tex]\sqrt{ab} = -\sqrt{a}\sqrt{b}[/tex]
No, that's not true at all.
[tex]\sqrt{(-2)(-8)} = \sqrt{16} = 4 = \sqrt{2}\sqrt{8}[/tex]
Mentallic said:
And finally for the last case, a<0 b[itex]\geq[/itex]0
[tex]\sqrt{ab}=\sqrt{-a}\sqrt{b}=i\sqrt{a}\sqrt{b}[/tex]
Actually, if only one of a and b are positive, we don't know if the answer is multiplied by i or by -i, I believe. That non-property is used to show the fallacy in a certain 1=2 argument.
Has this thread something to do with the recent release of Alice in Wonderland?
Mark44: [itex]\sqrt{(-2)(-8)}=\sqrt{2}\sqrt{8}[/itex] (true) [itex]=(\sqrt{-2}\sqrt{-8})/i^2=-\sqrt{-2}\sqrt{-8}[/itex] (as in Xitami's formula)
Or setting [itex]b=1,\sqrt{a}\neq 0[/itex]:
Mentallic: [itex]1=i[/itex]
Char Limit: [itex]1=\pm i[/itex]
Of course I felt I can venture into this forbidden territory of complex numbers without any issues... I was wrong.
I'll have some fun here to try and explain where Martin's second expression could've arisen from.
a>0, b>0
[tex]\sqrt{ab}=\sqrt{(-a)(-b)}=\sqrt{-a}\sqrt{-b}[/tex]
[tex]=\frac{i^2}{i^2}\sqrt{-a}\sqrt{-b}[/tex]
[tex]=\frac{-1}{i^2}\left( i\sqrt{a}\right)\left( i\sqrt{b}\right)[/tex]
[tex]=\frac{-1}{i^2}(i^2)\sqrt{a}\sqrt{b}[/tex]
[tex]=-\sqrt{a}\sqrt{b}[/tex]
as required... I suppose :-p
Disclaimer: The first line, while mathematically sound, isn't allowed to be used in this square root function.
I'm not sure what you're getting at here. We were assuming a<0 so [itex]\sqrt{a}\neq 0[/itex] is a given.
If by second expression you mean [itex]\sqrt{2}\sqrt{8}[/itex] it was copied from Mark44's post (as was the first expression [itex]\sqrt{(-2)(-8)}[/itex], but for some reason itex doesn't extend the square root sign - it should have read [itex]\sqrt{(-2)(-8)}[/itex]).
The third expression comes from [itex]\sqrt{-2}=i\sqrt{2},\sqrt{-8}=i\sqrt{8}[/itex] and substitution in the second expression.
The fourth expression comes from replacing [itex]i^2[/itex] by [itex]-1[/itex] and looks very much like what Xitami said and Mark44's post is claiming to be wrong.
What I'm getting at is you're claiming [itex]\sqrt{ab}=i\sqrt{a}\sqrt{b}[/itex] when [itex]a<0,b\geq 0[/itex]. Substituing [itex]b=1[/itex] (which is [itex]\geq 0[/itex]) gives, for [itex]a<0[/itex]
[itex]\sqrt{a.1}=i\sqrt{a}\sqrt{1}[/itex]
or [itex]\sqrt{a}=i\sqrt{a}[/itex]
and after division by [itex]\sqrt{a}[/itex] which is possible because, as you point out [itex]a<0[/itex] therefore [itex]\sqrt{a}\neq 0[/itex]
[itex]1=i[/itex]
The "some reason" is that you switched from [ tex] tags to [ itex] tags.
[itex]1=i[/itex]
[itex]1=i[/itex]
but for a<0, [tex]\sqrt{a}=i\sqrt{-a}[/tex]
This isn't right. Neither equality is valid under the given conditions.
Since the possiblility of b being zero doesn't add anything useful, let me assume that b > 0 for the rest of the discussion, and that a < 0 as before.
[tex]\sqrt{ab} \neq \sqrt{-a}\sqrt{b}[/tex]
In the expression on the left, ab < 0 so its square root is imaginary. In the expression on the right, both radicands are positive, so each square root is real and positive, making the product real and positive.
[tex]\sqrt{-a}\sqrt{b} \neq i\sqrt{a}\sqrt{b}[/tex]
For reasons already given, the left side above is real and positive. The right side above is also real, but negative. The reason for this is that
[tex]i\sqrt{a}\sqrt{b} = i^2 \sqrt{-a}\sqrt{b}= -\sqrt{-a}\sqrt{b}[/tex]
It might be helpful to show this with numbers instead of variables, replacing a with -2 and b with 8.
[tex]i\sqrt{-2}\sqrt{8} = i^2 \sqrt{2}\sqrt{8}= -\sqrt{2}\sqrt{8}[/tex]
I think we have succeeded in going well beyond what the OP asked, and might have further confused him/her with a lot of extraneous information. I hope we are done here.
I might very well agree with that. You can divide by [itex]i\sqrt{-a}[/itex] and prove [itex]1=i[/itex] that way if you like.
But if you want to leave the rabbit hole you'll need to change your original equation.
I thought that was more or less what I said.
I don't think there was any confusion up to and including Xitami's first (correct) post, but it went downhill from there. All that was required at that point was a correct formula for [itex]\sqrt{ab}[/itex] for real [itex]a,b[/itex] of opposite sign.
I think that what we have here is notation error...
How about this then?
For positive real a and b...
[tex]\sqrt{(-a)(b)}=\sqrt{-a}\sqrt{b}=i\sqrt{ab}[/tex]
Of course, a similar argument cannot be done for -a and -b because the square root function can't be "split" with two negative radicands. No, it can't.
If you want to avoid confusion it's probably not a good idea to change the meaning of [itex]a[/itex] and [itex]b[/itex] from those in the original question (repeated under).
For real [itex]a[/itex] and [itex]b[/itex], [itex](ab)^{0.5}=a^{0.5}b^{0.5}[/itex] unless both [itex]a[/itex] and [itex]b[/itex] are negative, in which case [itex](ab)^{0.5}=-a^{0.5}b^{0.5}[/itex].
No, if a and b are both negative, than the result is invalid. And I already proved the result if either a or b is negative.
Wikipedia on the Square Root Function said:
Note that because of the discontinuous nature of the square root function in the complex plane, the law √zw = √z√w is in general not true. (Equivalently, the problem occurs because of the freedom in the choice of branch. The chosen branch may or may not yield the equality; in fact, the choice of branch for the square root need not contain the value of √z√w at all, leading to the equality's failure. A similar problem appears with the complex logarithm and the relation log z + log w = log(zw).) Wrongly assuming this law underlies several faulty "proofs", for instance the following one showing that −1*=*1:
So if both a and b are negative, the result is invalid (actually multivalued).
If either a or b is negative, my result follows above.
From the original question:
Ali Asadullah said:
... when a and b either both are negative or one of them is negative.
From your post:
Char. Limit said:
... For positive real a and b...
What I was suggesting is that this is likely to lead to confusion.
By "the result" here, do you mean the result given in the original question or the result I gave in answer?
If the former then I would agree with you. That is the import of the minus sign in the last expression in my answer.
If the latter, can you give a specific pair of real values for a and b where you think the answer is incorrect?
With the usual definition of [itex]z^w[/itex] for complex [itex]z,w[/itex] viz. [itex]z^w=e^{w Log(z)}[/itex] the Log is taken to be the principal log, so the function is single valued, so I think your remarks about the result being multivalued are mistaken if by "the result" in this case you mean one of (ab)0.5, a0.5 or b0.5.
I mean your result.
[tex]\sqrt{(-2)(-8)}=\sqrt{16}=4[/tex]
I only used multiplication and the square root of a positive number. If a and b are negative, the answer is a real, positive number, and your result is invalid. Assuming we don't take the principal root (always possible)...
[tex]\sqrt{(-2)(-8)}=\sqrt{16}=4 , -4[/tex]
Which is multivalued. So if the principal root gives you a real, positive number, and the general root gives you multiple values, you won't receive a singlevalued negative real number from your operations.
(Note: I did post the wrong Wikipedia section... They are talking about complex numbers, not negative numbers. Sorry for that mixup.)
Char. Limit said:
I mean your result.
This is the same example that Mark44 previously used. As I said regarding that example:
... Mark44: [itex]\sqrt{(-2)(-8)}=\sqrt{2}\sqrt{8}[/itex] (true) [itex]=(\sqrt{-2}\sqrt{-8})/i^2=-\sqrt{-2}\sqrt{-8}[/itex] (as in Xitami's formula)
the result agrees with Xitami's formula, which matches my answer for [itex]a,b[/itex] both negative. So that is not a counter-example.
Both notations [itex]z^{0.5}[/itex] and [itex]\sqrt{z}[/itex] are defined as the principal root (precisely to avoid multiple values). It's always possible for you not to take the principal root, but in that case you're not talking about the problem.
So I think the one line answer I included a few posts back was all that was really required for this thread.
PS. Neither OP nor I said anything about the expressions on either side being real. I would say it was clear that OP was well aware that they would not be.
You're assuming that [itex]\sqrt{ab}=\sqrt{a}\sqrt{b}[/itex] if both a and b are negative. This isn't true. After all, here's another equation using your same logic (it's your logic, right?)
[tex]-1=i^2=i \times i=\sqrt{-1}\sqrt{-1}=\sqrt{-1 \times -1}=\sqrt{1}=1[/tex]
And that's why [itex]\sqrt{ab}[/itex] does not equal [itex]\sqrt{a}\sqrt{b}[/itex] for negative a and b. Because if it did, -1 would equal 1.
Edit: Here's another place that shows the same logic, but with division. The relevant material is near the bottom.
http://www.math.toronto.edu/mathnet/falseProofs/guess11.html
Absolutely not. If you read what I wrote a little more carefully it says that [itex]\sqrt{ab}=-\sqrt{a}\sqrt{b}[/itex] if both [itex]a[/itex] and [itex]b[/itex] are negative. This gives you:
[itex]-1=i^2=i\times i=\sqrt{-1}\sqrt{-1}=-\sqrt{-1\times -1}=-\sqrt{1}=-1[/itex]
No surprise there.
Ok, then tell me why every single calculator I've used on this iPod (six at last count) gave me real and positive numbers for every square root of the product of two negative numbers that I put in? According to you, those numbers should be negative. Also, shouldn't math be consistent? So why can't I multiply the numbers in the radicand to produce a positive product, when I can with ANY other number under that root sign? In other words, why does multiplying the numbers in the radicand and then taking the square root (all allowed formal operations) produce a positive number, but your method produces a negative number?
[itex]=\sqrt{-1}\sqrt{-1}=-\sqrt{-1\times -1}[/itex]
How did you come up with this?
The way I see it, and why I agree with Char.Limit is that [tex]\sqrt{-1}\sqrt{-1}=\sqrt{(-1)(-1)}[/tex] from [tex]\sqrt{a}\sqrt{b}=\sqrt{ab}[/tex]
The problem arises from the order the process is undertaken. Repeating what wikipedia said that Char.Limit posted,
[tex]1=\sqrt{1}=\sqrt{(-1)(-1)}=\sqrt{-1}\sqrt{-1}=i^2=-1[/tex]
or
[tex]1=\sqrt{1}=\sqrt{(-1)(-1)}[/tex] (now at this point we multiply under the brackets first, to go back to the previous equality, in which case we will get 1 again).
. . . what a quagmire. Roots are multi-valued. [itex]\sqrt{1}=\pm 1[/itex]. And if you carry this multivalued notion throughout the process, then [itex]\sqrt{ab}=\sqrt{a}\sqrt{b}[/itex] for any values of a and b. For example,
[itex]\sqrt{(-2)(4)}=\sqrt{-2}\sqrt{4}=\sqrt{-1}\sqrt{2}\sqrt{4}=\pm i 2\sqrt{2}[/itex]
[itex]\sqrt{(-2)(-4)}=\sqrt{-2}\sqrt{-4}=\sqrt{-1}\sqrt{2}\sqrt{-1}\sqrt{4}=\pm i 2(\pm i)\sqrt{2}=\pm 2\sqrt{2}[/itex]
even:
[itex]\sqrt{(2)(4)}=\sqrt{2}\sqrt{4}=(\pm 2)(\pm \sqrt{2})=\pm 2\sqrt{2}[/itex]
you've really got to get a handle on this concept because this is just the lowly square root with just two values. What happens when we up the root or consider the log function or inverse trig functions which are really infinitely-valued (in the complex sense)? For example, can I:
[itex]\sqrt[3]{(-4)(2)}=\sqrt[3]{-4}\sqrt[3]{2}[/itex]?
and just carry-over the multiple-valued [itex]\sqrt[3]{-1}[/itex] throughout the steps and write:
[itex]\sqrt[3]{(-4)(2)}=\sqrt[3]{-4}\sqrt[3]{2}=\sqrt[3]{-1}\sqrt[3]{4}\sqrt[3]{2}[/itex]
with the understanding that we interpret the cube-root of -1 as actually three values and [itex]\sqrt[3]{2}[/itex] and [itex]\sqrt[3]{4}[/itex] as the positive cube-roots.
Curiouser and curiouser ...
I would ask you again to read my answer carefully.
According to that answer, when [itex]a[/itex] and [itex]b[/itex] are both negative [itex]\sqrt{ab}[/itex] is positive.
Specifically:
[itex]\sqrt{ab}=-\sqrt{a}\sqrt{b}=-i\sqrt{-a}.i\sqrt{-b}=-i^2\sqrt{-a}\sqrt{-b}=-(-1)\sqrt{-a}\sqrt{-b}=+\sqrt{-a}\sqrt{-b}[/itex]
and the two square roots on the right are positive by definition.
When you ask if you can multiply two numbers in a radicand the answer is, "of course". What you can't do is assume the universal applicability of [itex]\sqrt{ab}=\sqrt{a}\sqrt{b}[/itex] with the standard definition of "[itex]\sqrt{}[/itex] ".
jackmell said:
. . . what a quagmire. Roots are multi-valued. [itex]\sqrt{1}=\pm 1[/itex]. ...
Quagmire indeed. But defining roots to be in a Cheshire cat like state between one value and another will only make it more treacherous.
According to any respectable definition [itex]\sqrt{1}=1[/itex]. The solutions of [itex]x^2=1[/itex] are [itex]\pm 1[/itex].
Directly from the answer I left for OP with a=-1 and b=-1.
As Char.Limit himself was at pains to point out (correctly), the identity [itex]\sqrt{a}\sqrt{b}=\sqrt{ab}[/itex] that you quote is invalid. You can use the formula I posted for real numbers.
But I would guess that Wikipaedia makes it clear that this is a fallacy. 1 and -1 really are not the same with their generally accepted meanings.
You're looking only at the shadow when you take [itex]\sqrt{1}=1[/itex] when in reality, the (complex-analytic) function consists of two twisted surfaces in 3D space. Most (all?) of the functions you deal with in math are like that except in real calculus, we only concern ourselves with their cross-sections along one or more real axes which are often times, real-valued. Same way in differential equations. What I'd like to get across is if students would somehow begin to understand this more "global" definition of the functions in terms of their complex-analytic counterparts, then this quagmire would become less so. However I suspect some teachers would argue that just the real analysis is difficult to learn and injecting the complex part too soon would only empty the classrooms.
