Simple 8-bit FFT Processor for 512pt Array at 20MHz
Ravaner
Hello. I'm looking for a "simple" FFT processor able to process an 8 bits input in an array of at least 512 pts with a speed of at least 20 MHz. I've precised "simple" instead of certain TI DSP with up to 196 pins ! I only need FFT nothing else. Does it exist ? Thanks by advance for replies.
Tough to answer without checking the DS of a bunch of processors - Digikey sort may help
Do you just want the processor - for a product development, or is this a one off build - although a Dev Kit would help with both.
Does that mean you want to process the whole array from input time domain data to output frequency domain data once every 1/20MHz = 50ns? That's pretty fast for a simple processor, IMO. There may be some purpose-built chips that can be used to pipeline and accelerate the transform, though.
EDIT -- Or do you mean you just want your hardware clock for this processing to run at 20MHz? How often do you need for the FFT to complete?
If the 20MHz is the data acquisition rate, then it can be done continuously on an Intel CPU in a PC.
There is code available for FPGAs that will generate pipelined parallel FFT processors for the highest speeds.
