Simple Experimental Error Problem
2 replies · 3K views · last reply
Lavace
I have two values:
r = 12.3 ± 0.2m
d = 0.57 ± 0.03mm
I want to divide the two values to find theta (d/r = theta), how do I go about this?
I assume that I add the experimental error margins together after the division of 12.3 and 0.57? Giving me:
4.63 x 10^-5 ± 2.0003m
I cannot figure out what you've done here but 2.0003 m does not look like an appropriate uncertainty for an angle. The way this is usually done is through fractional uncertainties. The fractional uncertainty for the radius is
[tex]\delta_{r}= \frac{\delta r}{r} = \frac{0.2}{12.3}[/tex]
and for the arclength
[tex]\delta_{d}= \frac{\delta d}{d} = \frac{0.03}{0.57}[/tex]
Then the fractional uncertainty for the angle is
[tex]\frac{\delta\theta}{\theta} = \sqrt{\delta^{2}_{r}+\delta^{2}_{d}}[/tex]
For division of variables on would normally treat the erros like so.
[tex]\frac{\delta q}{q} = \sqrt{\left(\frac{\delta r}{r}\right)^2 + \left(\frac{\delta d}{d}\right)^2}[/tex]
