Simple Harmonic Motion and maximum velocity
The discussion focuses on solving problems related to Simple Harmonic Motion (SHM) and spring constants. The first problem involves two objects oscillating on springs with known spring constants, where the spring constant of spring 2 is determined to be 696 N/m. The second problem addresses the stretching of a spring when a ball is whirled in a horizontal circle, with the final answer for the stretch when hanging motionless calculated as 2.29 x 10^-3 m. Key equations used include F=kx and the relationship between maximum velocity and amplitude in SHM.
  • Understanding of Simple Harmonic Motion (SHM)
  • Knowledge of spring constants and Hooke's Law (F=kx)
  • Familiarity with centripetal acceleration in circular motion
  • Ability to manipulate and solve equations involving oscillatory motion
  • Study the derivation of maximum velocity in Simple Harmonic Motion
  • Learn about the relationship between amplitude and spring constant in SHM
  • Explore the concept of centripetal acceleration and its application in oscillatory systems
  • Investigate the effects of mass on spring constant calculations in oscillatory motion
Students studying physics, particularly those focused on mechanics and oscillatory motion, as well as educators seeking to clarify concepts related to Simple Harmonic Motion and spring dynamics.
kiro626
[SOLVED] Simple Harmonic Motion
I'm really having a hard time solving these two problems.
1. Objects of equal mass are oscillating up and down in simple harmonic motion on two different vertical springs. The spring constant of spring 1 is 174 N/m. The motion of the object on spring 1 has twice the amplitude as the motion of the object on spring 2. The magnitude of the maximum velocity is the same in each case. Find the spring constant of spring 2.
the relevant equations are those for SHM. F=kx and f=-kx.
I tried the formulas but I still can't find the answer. The answer is supposed to be 696N/m
2nd problem:
A small ball is attached to one end of a spring that has an unstrained length of 0.200 m. The spring is held by the other end, and the ball is whirled around in a horizontal circle at a speed of 3.00 m/s. The spring remains nearly parallel to the ground during the motion and is observed to stretch by 0.010 m. By how much would the spring stretch if it were attached to the ceiling and the ball allowed to hang straight down, motionless?
same as the one above
Again with this one, I tried solving it using the same formula but I can't figure how to use the velocity since its in m/s rather than rad/s for uniform circular motion. The answer is supposed to be 2.29 x 10^-3
Any help would be gladly appreciated
This is quite a neat problem. The position of the spring is given by y = A sin(\omega t) where A is the amplitude and \omega = \sqrt{\frac{k}{m}}. You need to work out what the velocity will be and then set them equal. REmember the max velocity will be at the equilibrium point.
I already solved the first problem but I still can't figure the second one out. I tried equating the constant of spring since they would be equal but it give me 2.18x10^-3 so its a little off
WEll if you show your full work it would help me. I suspect you're using the wrong value for r.
uhmm... for the second problem i used the equation:
ma = kx
wherein a is centripetal acceleration
i used 0.2 as the r and then 0.01 as the x to get the k then i equated the k from the second equation that i made which is:
mg = kx(sub2)
I'm not really sure about it
it shall do a lot of good if you tell us why are you not sure?
ma = kx
mg = kx(sub2)
I'd have used 0.21 as r.
thanks I finally got the answer. I finally understood it ^^ thanks very much.
  • · Replies 18 ·
