Simple Harmonic Motion: Giancoli Problem Help
The discussion revolves around a problem involving simple harmonic motion, specifically analyzing the oscillation of a 1.15-kg mass described by the equation x = .650cos(8.40t). Participants are tasked with determining the amplitude, frequency, total energy, and kinetic and potential energy at a specific position.
  • Mixed
  • Participants explore the definitions of amplitude and frequency, with one noting the amplitude is given directly in the problem. There is confusion regarding the calculation of total energy, with some questioning the use of gravitational potential energy in the context of the problem. Others express uncertainty about the appropriateness of certain equations and relationships, such as k = mg/x, in this scenario.
Several participants are actively engaging with the problem, raising questions about the assumptions made regarding gravitational effects and the applicability of certain equations. Some guidance has been offered regarding the conservation of energy and the context of the spring-mass system, but no consensus has been reached on the correct approach to the total energy calculation.
The problem statement is noted to be vague, leading to various interpretations of the forces acting on the mass and the nature of the oscillation. Participants are also considering the implications of deriving equations to clarify their understanding of the relationships involved.
hstone
A 1.15-kg mass oscillates according to the equation x = .650cos(8.40t) where x is in meters and t in seconds. Determine a)the amplitude, b)the frequency, c) the total energy of the system, and d) the kinetic and potential energy when x = 0.360m.
x = Acosωt
ω = 2πf
Etotal = KE + PEs +PEg = 1/2mv² + 1/2kx² + mgy
v = rω
∑F = ma
F = kx
a) Amplitude is given in the problem. A = .650m
b) Frequency f = ω/2π = 8.40/2π = 13.2 Hz
c) Total Energy E = 1/2mv² + 1/2kx² + mgy
This is where I am having difficulty, and feel like I am taking a complicated route and overlooking a simple solution. I assume there is no gravitational potential energy, since the problem doesn't mention any change in height. Simplifying and manipulating the equation for total energy I get the following:
E = 1/2m(Aω)² + 1/2(mg/x)(x²) = 1/2m[(Aω)² + gx]
E = 1/2(1.15)[(8.40*0.650)² + 9.8*0.360] = 19.2 J
I don't think this is correct, since I'm pretty sure I'm not supposed to use x = 0.360 in the equation. If I use the equation given in the problem I'd need to know t. I don't think this is the right way of going about this problem. I know I am not thinking about this correctly, and all of the possible equations and different forms are muddling my thought process.
Can I just calculate the total energy at ANY position to make this simpler? If so, I would use the equilibrium position x = 0, and my equation would be E = 1/2m(Aω)² = 17.14 J.
x = Acosωt
ω = 2πf
v = rω
∑F = ma
F = kx
Did you mean 1.32 Hz? Since ##2\pi## is greater than 1, numerically ##f## should be less than 8.40.
That's right. The only potential energy in this problem is the spring's.
Yes, you can. Energy is conserved, so if you calculate the total energy at anyone place in the cycle, you know the total energy throughout the cycle.
One mistake you are making is using the relation ##k = mg/x##. This applies to a mass hanging from a spring, where x is the amount the spring is stretched when the mass is in equilibrium. Since you don't have a mass hanging from a spring, you can't use that. You do have a relation that always applies to a mass-and-spring harmonic oscillator. You can use it to solve for ##k##.
When the spring force is the only force acting on the mass doesn't k = mg/x apply, since ΣF=kx=ma and the only acceleration is due to gravity? Should I be using ω=√(k/m), instead?
There are so many relations, I'm having difficulty keeping them all straight. I think I probably need to derive them all to be sure of where they are coming from.
Thanks so much for your help! It's greatly appreciated.
What are the forces on the mass? I'm assuming the problem is referring to a spring-mass system that moves horizontally. Is that right?
That'll work.
Deriving equations is good. It definitely helps you know when you can or can't use a particular equation.
The problem just states that 'a mass oscillates.' It's pretty vague. I can see now why k=mg/x wouldn't work, since k is constant and shouldn't change with x.
Thanks!
##k=mg/x## applies to a mass hanging from a weight, and it only holds as the position where the force exerted by the spring, kx, equals in magnitude the weight of the mass, mg. In other words, it holds for a specific value of ##x##.
I think it's safe to assume that you just have the archetypical harmonic oscillator, a mass connected to a spring and moving on a frictionless horizontal surface. Since the motion is horizontal, gravity doesn't play a role, which is another reason mg=kx wouldn't apply.
  • · Replies 51 ·
