Simple Harmonic Motion Question Advise required please
The discussion centers on calculating the maximum linear velocity, acceleration, and force on a crankshaft in a vehicle engine with a piston stroke of 180mm, operating at 4200 RPM. The user, Tom Brown, correctly converted RPM to radians per second and calculated the maximum linear velocity using half the stroke (90mm). However, the acceleration calculation resulted in an unusually high value of 1749.7 m/s², which was confirmed to be within a normal range for rotating machinery, as similar values are observed in jet engine rotor blades.
  • Understanding of Simple Harmonic Motion principles
  • Knowledge of angular velocity conversion (RPM to rad/s)
  • Familiarity with basic physics formulas for velocity and acceleration
  • Concept of force calculation using mass and acceleration
  • Study the principles of Simple Harmonic Motion in mechanical systems
  • Learn about angular velocity and its applications in engineering
  • Explore advanced calculations for forces in rotating machinery
  • Investigate the effects of acceleration in various mechanical components
Mechanical engineers, physics students, and anyone involved in the design or analysis of engine components and rotating machinery dynamics.
tomgbrown
Simple Harmonic Motion Question... Advise required please!
A vehicle engine has a stroke of 180mm. The motion of the piston is simple harmonic.
calculate max linear velocity and acceleration at 4200rpm?
Calculate max force to the crankshaft if the piston has an effictive mass of .35kg at an amplitude of half the stroke?
I have changed 4200rpm into rad/s and multiplied that value by half of 180mm=90mm=0.09m for max linear velocity? CORRECT?/
For acceleration i have used rad/s value squared multiplied by 0.09 and it gives a huge value of 1749.7m per second per second which seems wrong to me?
For the force part of the question is it as easy as force = .35 x the acceleration value ( if its right)
Any help would be much appreciated... i think I am on the right track but need a nudge in the right direction.
Cheers, Tom Brown
Your method looks OK, but I think your 1749m/s^2 was a typo for an even bigger number.
That sort of acceleration is quite normal for rotating machinery. For example the centripetal acceleration of some of the rotor blades in jet engines are of the order of 100,000 m/s^2.
16K
  • · Replies 21 ·
