Simple Harmonic Motion - Velocity EQ.
The discussion revolves around the velocity equation for an object undergoing simple harmonic motion, specifically given the position function x = 0.20m*sin(0.44 rad/s * t). Participants are exploring how to derive the velocity from this position function and questioning the validity of the provided solutions.
  • Participants discuss the correct form of the velocity equation, with some asserting that the derivative of the position function should yield a cosine function, while others question the phase shift in the equation. There are inquiries about the source of the velocity equation presented in the textbook and the implications of using radians versus degrees in calculations.
The discussion is ongoing, with multiple interpretations of the velocity equation being explored. Some participants have provided guidance on deriving the velocity from the position function, while others express confusion regarding the phase shift and its impact on the solution. There is no explicit consensus on the correct approach yet.
Participants are working under the constraints of homework guidelines, which may limit the information they can share. The original poster's attempt at deriving the velocity equation has led to confusion, particularly regarding the phase shift and the use of radians versus degrees in calculations.
Masri
Write the equation for the velocity of this object. Find the velocity at t = 4:0 s.
well, i know that v(t)= - wAsin(wt +[tex]\phi[/tex])
and we know the w = 0.44 rad/s
A = 0.20 s
t=4
so it i plugged the numbers in but the answer came wrong..
and the answer in the book says ...
v= 0.088 m/s* cos ( 0.44 rad/s * 4 s)
v= - 1.7 *10-2 m/s
well first where did he get that equation from ? 2nd if we actually calculated (v= 0.088 m/s* cos ( 0.44 rad/s * 4 s) ) it won't give us v= - 1.7 *10-2 m/s
so if someone could please help me out with this one... any help would be appreciated ,
Thanks!
v= - 1.7 *10-2 m/s
As i know, the calculation of the book was using radian(0.44) changed to degree(25.120).So,the answer would get -0.01655 m/s.
But for me, normally we usage radian.:smile:
but where did he get that formula from ?
hello,
your equation for the velocity is incorrect. can you show what you did to derive it?
(0.44rad/pi)x1800=25.120
eczeno said:
hello,
it is actually given to us like this in our formula sheet . (am talking about the on i used, not the one the book )
thanks xiaoB, but i was talking about the velocity equation that the book used
eczeno said:
hello,
Hi,eczeno!:smile:
Actually he correct because the sine has the phase ∅.
if the formula you gave for the position is correct, then your velocity is incorrect.
v = dx/dt. take the derivative of x to find v.
notice the solution has cosine where you have sine; the solution given is correct.
You just derive this x = 0.20m*sin(0.44 rad/s * t) respected for t :
dx/dt=V.
xiaoB said:
Hi,eczeno!:smile:
No, it's not correct. The derivative of A*sin(wt) is wA*cos(wt).
Yes ! the derive should be this wA*cos(wt) .
But if v(t)= - wAsin(wt + ∅) the sin(wt + ∅) for the phase ∅ is 900 so the sin(wt + 90)=cos(wt).:smile:
Therefore,v(t)= - wAsin(wt + ∅) nothings going wrong.:smile:
of course the addition of the proper phase will turn cos into sin, but there is no phase specified in the attempted solution, so it is incorrect.
this is really only adding unnecessary confusion to a relatively simple problem. the derivative of sin is cos; this gets us directly to the correct solution without needing to worry about the phase.
If I were first learning simple harmonic motion, that sort of approach to solving the problem would make me quit physics. That's what's going wrong.
Oh!thanks.I not think so...
  • · Replies 51 ·
