Deriving Simple Harmonic Motion Equations
The discussion focuses on deriving equations related to Simple Harmonic Motion (SHM) using a mass-spring system. A 16kg mass on a spring with a spring constant (k) of 9.0 N/m and a velocity of 2.0 m/s at the midpoint of motion is analyzed to find the amplitude. Key equations include F = -kx and the relationship between angular velocity and spring constant, specifically angular velocity = √(k/m). The conversation emphasizes deriving equations to enhance understanding of SHM concepts.
  • Understanding of Simple Harmonic Motion (SHM) principles
  • Familiarity with Hooke's Law (F = -kx)
  • Basic knowledge of differential equations
  • Concept of conservation of energy in mechanical systems
  • Derive the equations of motion for Simple Harmonic Motion
  • Learn about angular frequency and its relation to SHM
  • Explore the conservation of energy in oscillatory systems
  • Study the mathematical representation of SHM using sine and cosine functions
Students studying physics, particularly those focusing on mechanics and oscillations, as well as educators looking for insights into teaching SHM concepts effectively.
akj
Hi i need help with this question. It is focused on simple harmonic equation and the rest of the assignment uses many question which are structure like this.
A mass of 16kg on a spring of k = 9.0N/m passes the midpoint of motion with a velocity of 2.0m/s what is the amplitutde?
I am unsure what equation(s) i could use that contains mass, spring contanstant (k), velocity and amplitute or displacement.
I would be greateful for any help,
thanks in advance.
You should really show us what you've tried.
Use the equation relating angular velocity, mass, and k.
Then take a look at the equation for velocity given by the conservation of energy.
Remember at the midpoint/equilibrium x = 0.
Oh, and post homework questions in the homework forum!
thanks for your response. Are you referring to anqular velocity = square root[(k/m)]?. if so how do i relate this to working out the amplitute?
instead of trying to dig out which equations to use, why not derive all of them yourself, that way u will understand everything a lot better.
start with key equation F=-kx = m x'' where x'' is the 2nd derivative. etc. then you will find a form for x in terms of sin/cos ..etc. then using basic relations like ang freq = 2 pi f, 1/f = period etc you can solve for everything. Amplitude will just be the factor outside your sin/cos functions. NB: you have been given some conditions so that you can fix some of your integration constants.
  • · Replies 51 ·
