Master Simplifying Skills: How to Simplify Complex Equations
  • Thread starter Thread starter 1calculus1
The discussion focuses on simplifying the equation 2h + (16/(h-8) + 2)(-8/(h-8)^2) into 2h - 128/(h-8)^3 - 16/(h-8)^2. Key points include the multiplication of constants, where 128 is derived from 16 multiplied by -8, and -16 from 2 multiplied by -8. The confusion arises around the transformation of (h-8) into (h-8)^3, which is clarified by explaining that multiplying (h-8) by (h-8)^2 results in adding the exponents. The final expression is confirmed as 2h - 128/(h-8)^3 - 16/(h-8)^2, resolving the original query. The explanation emphasizes the importance of understanding exponent rules in simplification.
1calculus1
Simple Math-- Need help =/
1. Homework Statement [/b
I am confused on how this equation:
2h + (16/h-8 +2) (-8/(h-8)^2
is simplified to this equation:
2h - 128 (h-8)^3 - 16/(h-8)^2
Simplifying skills.
Well, I know that they got the number 128 from multiplying 16 and -8 together and how they got -16 by multiplying 2 and -8 together. Now, what I don't get is getting (h-8)^3 from (h-8)... SOMEONE PLEASE HELP?
If you have (A + B) * -C
and you want to expand it out you do -A*C - B*C ...do you see?
in your question A = 16/(h-8)
also if you have (1/y)(2/y^2)
you'll get 2/y^3
the top multiplied together and the bottom multiplied together... do you see?
do you mean that 2h - 128/(h-8)^3 - 16/(h-8)^2? if you meant that, then the (h-8)^3 comes from multiplying (h-8) times ( h-8)^2, what you do is you add the exponents.
It is like x times x, you add the exponents if the bases are the same, it becomes x^2, 5 times 5 is 5^2.
I'll be right back. I'm at school right now and bell is going to ring soon. Thanks for the replies, I'll look into it once I get home.
2h+( \frac{16}{h-8} + 2 ) ( \frac{-8}{(h-8)^2} )
let x = \frac{-8}{(h-8)^2}, then:
2h+( \frac{16}{h-8} + 2 ) x
2h+ \frac{16}{h-8} \times x + 2 \times x
sub x = \frac{-8}{(h-8)^2} back in:
2h+ \frac{16}{h-8} \times \frac{-8}{(h-8)^2} + 2 \times \frac{-8}{(h-8)^2}
2h+ \frac{16 \times (-8)}{(h-8) \times (h-8)^2} + \frac{2 \times (-8)}{(h-8)^2}
2h+ \frac{-128}{(h-8)^3} + \frac{-16}{(h-8)^2}
Does that clear it up?
  • · Replies 29 ·
