Optimizing Rectangle Dimensions for Area 1000m^2: A Simple Solution
  • Thread starter Thread starter physicsed
    Optimization
To find the dimensions of a rectangle with an area of 1000 m² and the smallest perimeter, the perimeter can be expressed as 2x + 2000/x. Differentiating this equation helps identify the minimum perimeter. The optimal dimensions are derived by setting the derivative equal to zero, leading to x being the square root of 1000, or approximately 31.62 m. Consequently, the corresponding y dimension can be calculated as 1000/x, resulting in a rectangle with dimensions that minimize the perimeter effectively.
physicsed
[SOLVED] simple optimization problem
find the dimensions of a rectangle with area 1000 m^2 whose perimeter is as small as possible
perimeter = 2x + 2y
area = xy
1000 = xy
y= 1000/x
perimeter = 2x + 2(1000/x)
am stuck
any help from anybody?
now differentiate!
should learn concepts from the book (if you don't know why you differentiate)
Simple approach:
plot your perimeter and pick and minimum value
this is realistic problem, so going for really large x and -ve x would be nonsense
2-(2000/x^2)=0
i think
physicsed said:
2-(2000/x^2)=0
i think
You think? ... have confidence!
2/1000=x^-2
no, try 2=2000/x^2
x=square root of .001?
x=\sqrt{1000}=\sqrt{10\cdot10^2}=10\sqrt{10}
how did u get that?
2=\frac{2000}{x^2}\rightarrow x^2=\frac{2000}{2}\rightarrow x^2=1000
thanks alot. am messed up today!
