Calculating Work Between Two Points on a Line – Simple Question
  • Thread starter Thread starter Master J
    Line Work
The discussion revolves around calculating the work between two points on a line, specifically points A(1, 0, 0) and B(0, 1, (pi^3)/8). The parametric equation for the line connecting these points is correctly expressed as r = i + t(-i + j + [(pi^3)/8]k). Participants confirm that substituting t = 0 yields point A and t = 1 yields point B, validating the equation's correctness. The vector from point B to point A is derived by subtracting the position vector of A from that of B. The conversation clarifies the confusion regarding the position vector and the derivation of the line's equation.
Master J
Simple question.
So in an example question I'm lookin at finding the work between 2 points on a line.
The points are A(1, 0, 0) and B(0, 1, (pi^3)/8)
The vector of the line joining these points is then given as:
r = i + t(-i + j + [(pi^3)/8]k )
Is that correct? I can't see how that equation arises? It could just be a typo, or I'm just having a stupid day!
Cheers!
No, that's the parametric equation of the (straight) line connecting those points. Taking different values of t in the range [0,1] gives you different points along that line.
Yes, but is it correct? Shud there be a -i in there?
Is it r = a + tb ?
It looks OK to me. Substitute t = 0 and you get point A. Substitute t = 1 and you get point B. In unit vector notation,
\vec A = 1 \hat i + 0 \hat j + 0 \hat k
\vec B = 0 \hat i + 1 \hat j + \frac{\pi^3}{8} \hat k
I guess I'm confused as to that vector. How do you make that position vector from those 2 points?
The vector from B to A is simply
\vec{B} - \vec{A}
  • · Replies 20 ·
