MHB How would you simplify this logarithmic expression?
  • Thread starter Thread starter paulmdrdo1
    Expression
The logarithmic expression $\frac{1}{5}\ln|\sin5x|+\frac{1}{5}\ln|\csc5x-\cot5x|$ can be simplified by first factoring out $\frac{1}{5}$. This leads to $\frac{1}{5} \left[ \ln |\sin 5x | + \ln |\csc 5x - \cot 5x| \right]$, which can be combined into a single logarithm as $\frac{1}{5} \ln |\sin(5x)(\csc(5x) - \cot(5x))|$. Further simplification results in $\frac{1}{5} \ln |1 - \cos(5x)|$. The final expression can be expressed as $\frac{1}{5} \ln \left| 2\sin^2 \frac{5x}{2} \right|$, removing the absolute value as the expression is positive.
paulmdrdo1
how would you simplify this
$\displaystyle \frac{1}{5}\ln|\sin5x|+\frac{1}{5}\ln|\csc5x-\cot5x|$
please explain.
Mathematics news on Phys.org
Re: simplification of expression
What have you tried?
i just factored out the 1/5 and I'm stucked.
Hello Paul! Notice you can factor the $1/5$, yielding $$\frac{1}{5} \left[ \ln |\sin 5x | + \ln |\csc 5x - \cot 5x| \right],$$ and from here use that $\ln a + \ln b = \ln (ab)$. Consequently
$$\frac{1}{5} \left[ \ln |\sin 5x | + \ln |\csc 5x - \cot 5x| \right] = \frac{1}{5} \left[ \ln |\sin (5x) \cdot (\csc (5x) - \cot (5x) )| \right] = \frac{1}{5} \left[ \ln |1 - \cos (5x)| \right].$$
Cheers. :D
Hello, paulmdrdo!
\text{Simplify: }\:\tfrac{1}{5}\ln|\sin5x|+\tfrac{1}{5}\ln|\csc5x-\cot5x|
\begin{array}{ccc}\text{Factor:} & \tfrac{1}{5}\big(\ln|\sin5x| + \ln|\csc5x - \cot5x|\big) \\ \\ \text{Combine logs:} & \tfrac{1}{5}\ln|\sin5x(\csc5x - \cot5x)| \\ \\ \text{Distribute:} & \tfrac{1}{5}\ln|\sin5x\csc5x - \sin5x\cot5x| \\ \\ \text{Simplify:} & \tfrac{1}{5}\ln|1-\cos5x| \\ \\ \text{Further?} & \tfrac{1}{5}\ln\left|2\sin^2\! \tfrac{5x}{2}\right| \end{array}
soroban said:
Hello, paulmdrdo!
In the last step we can remove modulo sign as it positive
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
