Simplifying an expression using limits
8 replies · 2K views · last reply
whatisreality
Given that
##T = \frac{4E(V-E)}{4E(V-E)+V^2\sinh^2 (ka)}##
Simplify the expression for T when a is large but not infinite, and again for the case when a tends to zero and the potential tends to infinity, such that ##d = Va## is a real constant. k is a constant, as is E (which is assumed to be less than V).
To try and simplify it for the first case, I used the exponential definition of sinh, squared it and got that
##\sinh^2(x) = \frac{1}{4}(e^{2x}+e^{-2x}-2)##
For large x the ##e^{-2x}## term would get small very quickly, especially compared to the other exponential term which would increase rapidly. So this becomes
##\sinh^2(x) = \frac{1}{4}(e^{2x}-2)##
I don't know if that's what the question meant. It doesn't seem massively simpler. Is there something else that can be done to simplify the expression?
And the second part, I don't know where to start! There should be some sort of constant ##d = Va##, but I thought ##sinh^2(0)=0##, which would mean that ##a## disappears. As far as I can see that expression simplifies to 1 for the second set of limits! Why is that wrong?
What is the dominating term in the denominator?
The limit is such that a tends to zero while V tends to infinity at the same time, so the limit of the term [itex]V^2 \sinh^{2}(ka)[/itex] cannot be done simply by setting a = 0 as you've done. A good starting point is to Taylor expand [itex]\sinh^{2}(ka)[/itex], and see where that gets you to, before taking the limits.
whatisreality said:
Given that
Even better in the large-##a## case would be to write ##\sinh^2(x) \sim e^{2x}/4##, because ##e^{2x}## is overwhelmingly large compared to the 2. Also, if ##E(E-V)## remains constant, it is overwhelmingly small compared with the second term in the denominator, and that leads to even more simplification.
It would help to note that
$$k^2 = \frac{2m(V-E)}{\hbar^2}.$$ Since ##ka## depends on both ##a## and ##V##, you need to first figure out how it behaves in the limit as ##a \to 0## and ##V \to \infty## before writing down an approximation for ##\sinh ka##. Start by writing ##V = d/a## and getting everything in terms of ##a##.
Oh, I completely forgot about that! Thanks, I'll rewrite in terms of ##a## now.
In terms of a, ##ka = \frac{\sqrt{2mad - 2ma^2E}}{\hbar}##.
That still tends to zero, given d is a real constant. So ##sinh^2(ka)## tends to zero, since its taylor expansion is ##x^2 + \frac{x^4}{3} + \frac{2x^6}{45}##.
Taking the ##V^2## term into account, how do I know what happens? I've never dealt with composite limits before, it kind of looks like V tends to infinity just as fast as the ##sinh^2## term tends to zero!
Sorry, misplaced # in the post above.
Is getting everything in terms of a equivalent to getting it in terms of V, or do both cases have to be considered?
Why not try multiplying [itex]V^{2}[/itex] to your Taylor series expansion and see what you get? There'll be some simplifications that allow you to take the limit properly.
[Hint: use Va = d]
