Simplifying this expression for large values of D
13 replies · 3K views · last reply
CuppoJava
Show that:
p(r'+e) [tex]\cong[/tex] p(r')*exp( -3e2 / 2s2 ) for large D
given that:
p(r) = rD-1 * exp( -r2 / 2s2 )
r' = sqrt(D) * s
This arises out of a D-dimensional gaussian distribution and r' is the radius at which the probability is maximized.
I've gotten to the point:
p(r'+e) [tex]\propto[/tex] exp( -(r'+e)2 / 2s2 + (D-1)ln(r'+e) )
And the solution manual says that using the Taylor expansion for ln, will help everything reduce down, but all I get is a mess. What really baffles me is where the dependence on D went.
Thanks very much for your help
-Patrick
According to Wolfram Alpha, this is true for large s but not for large D.
Thanks for helping foxjwill. I'm almost certain that the result is correct though. There's an probabilistic interpretation of it, and it requires that this holds true for large D not s.
Wolfram Alpha, though, seems like an extremely useful tool. I haven't heard of it before. May I ask exactly what you typed into the query box?
Thanks
-Patrick
For large [itex]D[/itex], what can you say about the size of [itex]\frac{e}{r'}[/itex]? Use that to Taylor expand the logarithm:
[tex]\ln(r'+e)=\ln(r'(1+\frac{e}{r'}))=\ln(r')+\ln(1+\frac{e}{r'})[/tex]
First, I typed in
Code:
(exp(-3epsilon^2/(2s^2)) *r^(D-1)*exp(-r^2/(2s^2)) /  (r+epsilon)^(D-1)*exp(-(r+epsilon)^2/(2s^2)) )
Then I copied the result given in the Alternate form box:
Code:
r^(D-1) (r+epsilon)^(1-D) e^(-(r^2+r epsilon+2 epsilon^2)/s^2)
Finally, I pasted that into the input box, replaced each instance of r with "(s*sqrt(D))", then prepended "limit" and appended "as D->infinity":
Code:
 limit (s*sqrt(D))^(D-1) ((s*sqrt(D))+epsilon)^(1-D) e^(-((s*sqrt(D))^2+(s*sqrt(D)) epsilon+2 epsilon^2)/s^2) as D->infinity
Wolfram Alpha says this equals 0.
Something in this isn't quite right. If you work out the expansion around sqrt(D)*s you get a linear term in e. That's because the maximum value of your p(r) is at sqrt(D-1)*s NOT sqrt(D)*s, isn't it? Why don't you expand around the maximum? And I also don't get exp(-3*e^2/s^2) for the correction factor several different ways. I get just exp(-e^2/s^2).
Thank you very much for your help.
I haven't gotten then answer actually. It's a textbook question that asks me to prove the statement. (Exercise 1.20 from Pattern Recognition and Machine Learning by Bishop).
You're right. The maximum is actually at sqrt(D-1)*s, which the solution manual says can be approximated to sqrt(D)*s for large D. I will try expanding around sqrt(D-1)*s and see if I can get it.
Thank you for helping me.
-Patrick
Hi Dick,
Would you mind showing me how to arrived at exp(-e^2/s^2)?
I've tried expanding around r = sqrt(D-1)*s
and by noticing that (D-1)*s^2 = r^2
I simplified the equation to
p(r+e) approx. = exp( -(r+e)^2 + r^2*[ r+e-1 - ((r+e-1)^2)/2 ] )
By the way: is there a general rule for deciding when some approximations are valid and when some aren't?
eg. for large D: can I say e/r -> 0? or that r+e -> r?
CuppoJava said:
Hi Dick,
Where did the '(r+e-1)' stuff come from? Start with your expression in the first post exp(-(r'+e)^2/(2s^2)+(D-1)ln(r'+e)). Expand the (r'+e)^2, expand ln(r'+e) using fabbagabbahey's suggestion. Keep the linear and quadratic terms in the ln series. Collect like powers of e. What do you get?
Hi Dick,
Thank you very much for your help and patience.
Here's my work so far, I have an extra term at the end that I cannot get rid of
numerator:
[tex]-(r+e)^2+2(D-1)s^2(ln(r)+ln(1+e/r))[/tex]
[tex]=-(r+e)^2 + 2r^2(ln(r)+ln(1+e/r))[/tex]
[tex]=-r^2-2re-e^2+2r^2(r-1-(r-1)^2/2+e/r-(e/r)^2/2)[/tex]
[tex]=-r^2-2re-e^2+2r^2(r-1)(1-(r-1)/2)+2re-e^2[/tex]
[tex]=-r^2-2e^2+r^2(r-1)(1-r)[/tex]
Thanks
-Patrick
You do not replace ln(r) with (r-1)-(r-1)^2/2. You can only series expand small quantities. r (or rather you should be writing r') is not necessarily small. Just leave that term as ln(r'). Remember you want f(r')*exp(...). The ln(r') is part of the f(r').
Of course I can't expand around a large number. I should know that. Thanks again Dick.
I left ln(r') as it is, and finally I'm left with:
[tex]-r'^2+2r'^2ln(r') - 2e^2[/tex] in the numerator.
The first two terms are part of f(r'), and the last term is the correction term. I get a different coefficient (-2) in front of e^2 though. It's different from both your answer and the textbook answer. I'll keep on looking for what I did wrong.
-Patrick
You multiplied the quantity you are expanding by 2*s^2. You should divide it back out and get f(r')exp(-e^2/s^2).
