Sine and cosine law in oblique triangles
The discussion focuses on solving a word problem involving the leaning Tower of Pisa, which leans at an angle of 5.5 degrees. Using the sine law, the slant height of the tower was calculated to be 53.29 meters, while the height of the tower above ground was determined to be 53.04 meters. The calculations were confirmed as correct by other participants, emphasizing the importance of trigonometric principles in solving oblique triangle problems.
  • Understanding of sine law in trigonometry
  • Knowledge of angles and their applications in oblique triangles
  • Familiarity with basic trigonometric functions (sine, cosine)
  • Ability to solve word problems involving geometry
  • Study the application of the sine law in various oblique triangle problems
  • Learn how to calculate angles and lengths using trigonometric functions
  • Explore real-world applications of trigonometry in architecture and engineering
  • Practice solving similar word problems to enhance problem-solving skills
Students studying trigonometry, educators teaching geometry, and anyone interested in applying mathematical principles to real-world scenarios, particularly in architecture and engineering contexts.
aisha
Word Problem
The leaning tower of pisa leans toward the south at an angle of 5.5 degrees. One day a shadow was 90 m long and the elevation from the tip of the shadow to the top of the tower was 32 degrees
1)Determine the slant height of the tower.
First I found all the angles and then i used the sine law and got the slant to be 53.29 metres.
2) How high is the tip of the tower above ground?
I had a line from the tip of the tower perpendicular to the shadow and using sin=opposite/hypotenuse I determined what the opposite length was and got 53.04 metres
The two answers are quite close that's why I am not sure if I did this correctly can someone please check :redface:
Trigonometery is not my stong point, but I want to ask does it tell which direction the shadow of the tower is pointing?
From my expiences with these types of problems, id say the shadow is where the tower is leaning.
Okay, you ur awnsers, are corrent. :smile:
53.04 m is the right answer. Good job! :smile:
  • · Replies 18 ·
  • · Replies 28 ·
