Single-slit diffraction equations
  • Thread starter Thread starter AznBoi
    Diffraction
Single-slit diffraction involves understanding the intensity pattern created when monochromatic waves pass through a slit and hit a distant screen. The key equation for intensity is I = I₀(sin²β/β²), where β = (πb/λ)sinθ, with b as the slit width and λ as the wavelength. Zero intensity occurs at dark fringes due to destructive interference, while maximum intensity is at the central maximum. The pattern changes with variations in slit width or wavelength, affecting the angles of dark and bright fringes. It is important to differentiate between diffraction and interference, as they exhibit distinct behaviors in intensity distribution.
AznBoi
Please tell me what I need to know and what equations I need to use for these type of problems. Please define the variables in the equations too. Thanks.
-Sketch or identify the intensity patteren that results when monochromatic waves pass through a single slit and fall on a distant screen, and describe how this pattern will change if the slit width or the wavelength of the waves is changed and Calculate for a single-slit pattern, the angles or the positions on a distance screen where the intensity is zero.
What is intensity? Is it where the maximas (bright frindges) are? Is there zero intensity where there is a minima (dark fridge)?
I don't know if this is the right equation to use for the objective above:
sin \theta_{dark}=\frac{m\lambda}{a}
I guess the reason why I'm confused because it is not like diffraction/interference with a double-slit since the equation used in a double-slit actually gives you the position of the bright and dark frindges (places where the waves interefere constructively and destructively) while the single slit equation can only give you the angle from the central maxima where waves interfere destructively.
Am I right about this? Is there an equation where you can find the position of the dark/bright frindges from the central maxima? Thanks
You need to know how the intensity varies over the screen, in a single slit diffraction. For a single slit, the formula is:
I = I_{0}\frac{\sin^{2}\beta}{\beta^2}
where
\beta = \frac{\pi b}{\lambda}\sin\theta
where b is the slit width, \lambda is the wavelength of light used and I_{0} is the intensity at the central maximum (\theta = 0), i.e. the maximum intensity. Without a proper figure, it is not possible to make this clearer.
You should refer to a physics textbook (Halliday/Resnick, Sears/Zemansky, etc.) at this stage. You might also want to have a look at http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/sinslit.html
Hope this helps.
Sorry, I didn't read your second post while I wrote my first.
If you denote by D the distance from the source to the screen and y the distance of any point from the central bright fringe on the screen, then
\sin\theta = \frac{y}{\sqrt{y^2+D^2}}
If y is small compared to D (as is generally the case for interference), you can write approximately
\sin\theta = \tan\theta = \frac{y}{D}
and you can plug this in for \sin\theta and get y.
where
Hope this helps.
So basically, the places where there is zero intensity have a dark frindge (destructive interference) and the places where their is maximum intensity have a bright frindge (constructive interference)?
If you treat the slit as a source of several light 'beams'..(do you see what I am trying to get at, here?)
Did you see the hyperphysics link?
BTW, what textbook are you using?
[Sidenote: Studying interference before diffraction is natural, but when you switch to diffraction, you tend to think about it in the same way as interference. Thats how you can't explain the intensity pattern: in interference, the intensity doesn't fall off, so you tend to expect the same thing in diffraction. Strictly speaking, you shouldn't be neglecting diffraction effects in studying interference patterns...but when you do you get the simplified model that you already know so much about. Don't treat diffraction and interference as two totally distinct phenomena.]
I'm using college physics 7th ed. by serway/faughn. The books says that "the values of theta for which the diffraction pattern has zero intensity, where a dark fringe forms. The various dark fringes (points of zero intensity) occur at the values of theta that satisfy Sin\theta_{dark}=\frac{m\lambda}{a} a, being the width of the slit. So basically dark frindge=zero intensity, and bright frindge=max intensity?
Yup, and you can see that from the expression for intensity I gave a few posts ago.
Thanks a lot maverick. :smile: I really appreciate your help!
This is an old post, but just to clarify in case someone else has the same question in the future..
The bright fringes do not represent maximum intensity. Maximum intensity only occurs when theta is zero which is the bright fringe in the middle of the diffraction pattern. As theta is increased and you move further from the center of the diffraction pattern, the intensity decreases for each bright fringe. Just wanted to clarify that.
13K
