How Do I Calculate the Height and Diameter of My CSTR Reactor?
To calculate the height and diameter of a Continuous Stirred Tank Reactor (CSTR), a common guideline is to set the height at 1.5 times the diameter. For effective mixing, especially in slurry or viscous applications, a pitched-blade turbine with a diameter of half the tank diameter is recommended, positioned D/2 from the bottom. Additionally, incorporating vertical baffles at 90-degree intervals around the tank can enhance mixing efficiency. Specific mixing challenges, such as gas-liquid or liquid-liquid agitation, may require tailored approaches. Proper design is crucial for optimizing performance in processes like biodiesel production through esterification or transesterification.
princessme
I have obtained the volume of my CSTR, how do I calculate the height and diameter of it? Is there a certain ratio to adhere to for better mixing? Tried reading up the rules of thumbs but no info on that. Tried searching other books too but to no avail.
Slurry? Viscosity is high? Low? Gas-liquid mixture agitation? You might get ideas from searching some specific mixing problems.
Liquid-liquid mixture agitation, for production of biodiesel through esterification/transesterification.
I'd start with tank diameter D and height 1.5D, with one center-top-entering 45o pitched-blade turbine of diameter D/2 located a distance D/2 from the bottom. Add 4 - 1.4D high, 0.1D wide vertical tank baffles at 90o around the tank periphery.
I need to anneal 5052 aluminum for a home project. Google has given me mixed results on how to do this. Short version is that I'm doing some heavy forming on a piece of 5052-H32 and I'm running into issues with it work hardening. I've tried the Sharpie trick with a propane torch. But I'm not sure this is doing anything. I'm also seeing conflicting opinions whether to quench or air cool. So I'm looking for some expert opinions. (Oven heating is not an option due to size.) Thanks. edit: The...
39K
  • · Replies 0 ·
