Sketching Field Lines of f(r)r: A Guiding Intuition
The discussion revolves around sketching the field lines of the vector field defined by the expression f(r)r, where r is a position vector and f(r) is a scalar function of r. Participants are exploring the implications of the divergence and curl of this vector field in the context of visualizing field lines.
  • Participants discuss the challenge of sketching field lines without knowing the specific form of f(r). Initial attempts involve using vector calculus identities, and there is a suggestion to compute the divergence and curl of the vector field.
Some participants have computed the divergence and curl in Cartesian and spherical coordinates, noting the implications of these calculations. There is recognition that the divergence can vary based on the function f(r), and the curl being zero suggests that the field lines do not exhibit rotational behavior. Participants are considering how to represent different cases based on the sign of the divergence.
There is an emphasis on the unknown nature of the scalar function f(r), which complicates the visualization of the field lines. Participants are also navigating the transition between coordinate systems and the associated mathematical expressions.
MrB3nn
1. The problem statement, all variables and givenknown data
Let r be a position vector from the origin (r=xi+yj+zk), whose magnitude is r, and let f(r) be a scalar function of r. Sketch the field lines of f(r)r
1 [tex]\nabla[/tex]x([tex]\nabla[/tex][tex]\Psi[/tex])=0
2 [tex]\nabla[/tex].([tex]\nabla[/tex]xv)=0
3 [tex]\nabla[/tex]x([tex]\nabla[/tex]xv)=[tex]\nabla[/tex]([tex]\nabla[/tex].v)-[tex]\nabla[/tex][tex]\^{}2[/tex]v
4 [tex]\nabla[/tex].([tex]\Psi[/tex]v)=[tex]\Psi[/tex][tex]\nabla[/tex].v+v.[tex]\nabla[/tex][tex]\Psi[/tex]
I can't get started on this question. I have no idea how you can draw a sketch of the field lines when the scalar function is unknown. My intuition says you should be able to use some of those identities but I need a push in the right direction. I hope someone can give me that.
More relevant equations (the site was crashing when I tried to put them all into one post):
5 [tex]\nabla[/tex]x([tex]\Psi[/tex]v)=[tex]\Psi[/tex][tex]\nabla[/tex]xv+([tex]\nabla[/tex][tex]\Psi[/tex])xv
6 [tex]\nabla[/tex].(v.w)=w.([tex]\nabla[/tex]xv)-v.([tex]\nabla[/tex]xw)
7 [tex]\nabla[/tex]x(vxw)=v([tex]\nabla[/tex].w)-w([tex]\nabla[/tex].v)+(w.[tex]\nabla[/tex])v-(v.[tex]\nabla[/tex])w
Why not start by computing the divergence and curl of f(r)r...
Ok, I did that using the correct formulae.
Div:
3f(r)+x[tex]\partial[/tex]f(r)/[tex]\partial[/tex]x+y[tex]\partial[/tex]f(r)/[tex]\partial[/tex]y+z[tex]\partial[/tex]f(r)/[tex]\partial[/tex]z
Curl:
(z[tex]\partial[/tex]f(r)/[tex]\partial[/tex]y-y[tex]\partial[/tex]f(r)/[tex]\partial[/tex]z)i+(x[tex]\partial[/tex]f(r)/[tex]\partial[/tex]z-z[tex]\partial[/tex]f(r)/[tex]\partial[/tex]x)j+(y[tex]\partial[/tex]f(r)/[tex]\partial[/tex]x-x[tex]\partial[/tex]f(r)/[tex]\partial[/tex]y)k
I really can't see how that helps since I don't know f(r), and f(r) could be positive or negative. I know that the divergence of a vector field is the (flux of an infinitessimal box/unit volume) placed at a point in the field but I don't know how that helps. I don't know what curl is exactly so I don't know how that helps me visualise the field.
Yuck!...since f is a function only of r, use spherical coordinates to find the div and curl instead...remember, [tex]\frac{\partial f(r)}{\partial{r}}=f'(r)[/tex]
When I switch to spherical polars, r becomes r=r[tex]\widehat{r}[/tex] and grad changes appropriately.
For the div I get:
Div = f(r) + rf'(r)
and for the curl I get zero.
I still can't see what this means. The div could be positive or negative depending on the actual function.
The curl is zero, which tells you that the field lines don't 'rotate'...You are correct that Div (f(r)r) can be pos/neg or zero, so why not sketch and label all 3 cases?
Ok I see. Thanks very much for your consistent help.
