Sliding Block Attached to a Spring
A block with a mass of 2.90 kg is attached to a spring with a force constant of 492.0 N/m and experiences kinetic friction with a coefficient of 0.170. The block is pulled 5.30 cm from its equilibrium position and released from rest, prompting a discussion on calculating its speed at the equilibrium position. The work done by friction and the spring's potential energy are central to finding the block's speed, with emphasis on the work-energy theorem, which relates work done to changes in kinetic and potential energy. Clarification on the use of variable force in work calculations is also highlighted, noting that W = ∫ F dx is necessary when force is not constant. Understanding these relationships is crucial for solving the problem accurately.
AltruistKnight
A block with mass 2.90kg is attached as shown to a spring with a force constant of 492.0N/m. The coefficient of kinetic friction between the block and the surface on which it slides is 0.170. The block is pulled 5.30cm to the right of its equilibrium position and then released from rest. What is the speed of the block as it passes by its equilibrium position?
Rough image:
/\/\/\/\/\/\/\/|B_L_O_C_K|
PEspring=1/2kx^2
Fspring=kx
Ffriction=(mu)*Force Normal
Work=F*d
First, I found the force of Friction by multiplying the coefficient of friction by the force normal of the block due to gravity ("ma=mg=2.9*9.81=28.449N). Then, I attempted to use W=F*d to find the work done by friction. I then decided to try finding Wspring=F*d=kx*d (Where "d"=x, thus it would be "x^2"), and from there assumed that the Wnet=Wspring-Wfriction. However, that doesn't appear to be the proper method. In particular, if someone could explain the relationship of Work to Kinetic Energy AS WELL AS Potential Energy, that would be very helpful.
Hi AltruistKnight! :wink:
AltruistKnight said:
PEspring=1/2kx^2
correct :smile:
no, W = F*d only works if F is constant
if it isn't, you use W = ∫ F dx, which in this case is -1/2 kx2 (= -∆PE)
(btw, that was in your equations above … why didn't you use it? :confused:)
now carry on :smile:
the work-energy theorem says work done = change in mechanical energy (ie change in KE + PE) :wink:
(and potential energy is defined as minus the work done by a conservative force)
Likes proton007007
  • · Replies 37 ·
  • · Replies 45 ·
