Sliding Ramp and Freefall problem
The discussion revolves around solving a physics problem involving a sliding ramp and freefall, specifically determining the height (h) of the ramp. Participants analyze the motion of an object leaving the ramp, noting the components of acceleration as gsin(30) and gcos(30), while expressing confusion over how to derive a numerical answer for h due to missing variables. They explore using kinematic equations and relationships between vertical and horizontal distances but struggle with the interconnections of these variables. The conversation highlights the need to clarify definitions and relationships in the problem, particularly regarding the ramp's length and height, while emphasizing the importance of using algebraic expressions over numerical approximations. Ultimately, the group seeks a clearer path to solve for h using the information available.
Shaku
I typed this up on MP's Whiteboard, but the tutors were taking way too long to respond:
(question is also attached)
Edit:
Units are in meters.
Questions asks to Find h (small h defining the height of the ramp).
The exact moment the object leaves the ramp, it would have components Y=gsin(30) and X=gcos(30).
The motion starts with the incline, so it is useful to start the analysis there as well.
What do you know about the object at the end of the incline?
You can use this for the free fall afterwards.
Do you have any units for your values? Like... meters?
Yeah, I already tried that -- but I'd still be missing variables to do anything useful with the x and y components. It would be gsin(30) but I'm not sure where to go from there.
Units are in meters, and the problem has to solve for h (the small "h" defining the ramp's height).
In terms of h, what will the horizontal and vertical components of velocity be at the end of the ramp? (You can either determine the acceleration down the ramp or use conservation of energy.)
gsin(30) and gcos(30). But what am I supposed to do with that information? I'm still confused as we're supposed to reach an actual numerical answer for h.
Those are the accelerations. What about the velocities at the end of the ramp?
You are.
That's the problem I'm running into which I'm confused about -- I don't have enough information there to use kinematics to figure that out.
I don't have distance of the length adjacent to the angle, and I don't have time.
Δs = vi*t + (1/2)at^2
Which leaves me with three unknowns (time, velocity, and Δs).
Not numerically, no, but you have the unknown h. Use that. You only need an algebraic expression for velocity as a function of h. It doesn't matter that you don't yet know the value of h.
So, I would have:
Δh = 0(t) + (1/2)(a)(t)
= (1/2)(gSin(30)(t)^2
= (49/20)t^2
[STRIKE]Differentiating, I would get:
Δh = 2(49/20)t
= 4.9t[/STRIKE]
Where do I go from here? I don't know the time since it is an unknown variable. How would I go about finding the height once I have this equation?
Can you find the velocity (horizontally and vertically) at the end of the ramp as function of h? The determined value for the time can help.
Could you clarify what you mean? I found the function of h to be Δh = 4.9t...
These question-as-an-answer type responses are just confusing me more and more. I appreciate the help, but I'd more-so appreciate it if someone could try not being so cryptic in their responses.
No, that formula does not make sense. You cannot just derive one side, and ignore the other side.
Δh = (49/20)t^2
This is a relation between the length of the ramp and the time the object needs to go down. As you know the acceleration, what is the final velocity after that time?
How are the length of the ramp ("Δh") and h related? They are not the same...
Ohhhh, that makes much more sense.
Vfy = Vi + a(t)
Vfy = 0 + gSin(30)*(t)
Vfy = 4.9t
So I know:
ay = 4.9
Viy = 0
Vfy = 4.9t
Δh = (49/20)t^2
Plugging those values back in, I get:
Vf = Vi(t) + a(t)
4.9t = 0 + 4.9t
or
Δh = Vi(t) + (1/2)(a)(t)^2
(49/20)t^2 = 0 + (49/20)t^2
Which just cancels out if I try to do anything with that information... I'd guess that I would have to somehow figure out the time, and then use the time to figure out what Δh's length is. Using Δh's length and the angle, I'd be able to find h.
But I'm still very confused since I don't know how to proceed from here.
Vf=4.9t
You can solve Δh = (49/20)t^2 for t and plug it into the first equation. This gives Vf as function of Δh.
Right. Therefore, the first step is a relation Vf = (some expression with just h).
You can ignore the time in your equations if you know how to use energy conservation.
Once you have that: Vf is in the direction of the slope. Can you split it in a horizontal and a vertical component? Those are the initial conditions for the free fall afterwards.
Solving for t, I get:
Δh = (49/20)t^2
[Δh/(49/20)] = t^2
sqrt[Δh/(49/20)] = t
Plugging into the first equation, I get:
Vfy = (4.9)(sqrt[Δh/(49/20)])
We haven't learned conservation of energy yet; just general kinematics.
So now that I have Vfy as a function of Δh, how do I use that to solve for h?
If I plug in this Vfy as Viy of the freefall portion, I would still be missing too many variables to solve for anything on the y axis.
I'd be missing the same information on the x-axis too. We haven't learned conservation of energy yet -- when we were given this problem, it was given to us as-is.
We have to it solve with our current knowledge of kinematics.
You know the angles in the triangle...
You can find enough equations. Just keep on working with the variables*, you can solve for h at the end of the calculations.
*by the way: I think it would be easier to keep g as parameter as well, instead of using things like 49/20.
I'm confused again... I tried:
Plugging t into distance equation:
Δs = Vi(t)+(1/2)(a)(t)^2
Δh = 0 + (1/2)(gSin(30)(sqrt(Δh/2.45))^2
=(1/2)(gSin(30)(sqrt(Δh/2.45))
Δh = Δh ...?
Could you clarify what variables I'm trying to solve for, and how I'm supposed to solve for them? I tried a few different ideas, but I always ended up with strange numbers/variables that didn't work.
Here's what I have so far:
Let's back up here for a moment. Just realized I didn't check something you wrote earlier: you gave the components of the acceleration as gsin(30) and gcos(30). They're wrong.
Draw the free body diagram of the block. What are the forces on it?
I don't know why you changed "h" to "Δh". They seem to be the same thing, and you created some confusion by doing that. Also, as mfb says, it's much clearer to stick with symbols, like g, and leave the numbers until the end. It's easier to spot mistakes too. Ideally you should do that with the angles too, i.e. leave sin(30) as that instead of substituting 1/2, but I'll allow an exception there.
In many situations, including this one, C of E is the same as the kinematic equation vf2 = vi2+2as.
It is a frictionless ramp and the object starts at rest. The only force would be gravity, and the momentum it gains in the x-direction which is gCos(30).
Isn't Δh the hypotenuse of the ramp (aka, the ramp's length itself), and h is the height from which the object was released?
Wouldn't this just be the same as plugging the original two kinematic equations together (which is what I did here)?
It just end up being what I already had:
Vf = (4.9)(sqrt[Δh/(49/20)])
You try to solve everything at once, or insert equations into itself. That won't help.
Just consider what you have, and what you do not have yet, and how to connect them.
Look at your triangle, for example: How are h, the angle and Δh connected?
Ignore all other parts of the problem here!
No it isn't. Which way are you resolving forces to arrive at that? Vertically and horizontally or normally and tangentially to the ramp? You can do either, but you seem to be doing one then misinterpreting the answer as though you had done the other.
Isn't Δh the hypotenuse of the ramp ?
It is if you define it that way. I didn't see any such definition. If I missed it I apologise. But I think that approach will get messy - just use vertical and horizontal distances, not hypotenuse distances.
If we're talking just about this part of the problem, h would be:
h = Δh*Sin(30)
But Δh is in terms of t, which I don't have, so it would just become:
h = 4.25t2*Sin(30)
It makes sense that everything is connected, but I'm having a hard time putting the pieces together since there are still two unknowns which make it difficult to solve for h.
Could you clarify what steps I have left to do?
Maybe you should read the problem... It states that it is a frictionless ramp (and yes, I know, there is no such thing as a "frictionless ramp," but for the sake of the problem, there is no friction).
If you read through the replies of the other forum members, we defined it as the hypotenuse. It does require an extra mathematical expression at the end though to find h... But I wasn't sure how to define the horizontal distance since there wasn't enough information to relate to that easily. I just found the hypotenuse to be easier to work with, with the given information (or lack thereof!).
I'm aware of that, and your expressions for horizontal and vertical accelerations are still wrong. Consider this, if they were respectively g cos θ and g sin θ then the net acceleration would be the root-sum-square of these, giving g. I.e. it would accelerate down the ramp as fast as a dropping stone. Not possible unless the ramp is vertical.
So humour me: write out equations for the forces and accelerations.
I see your point... But the acceleration is at the end of the ramp, as in, the moment right as it reaches the very end of the ramp. At that point, it WOULD have -9.8 as its' acceleration, and its' components would indeed be falling as fast as dropping a stone. This is why we chose to start off at that moment when it is at the end of the ramp so we can avoid the friction component of it altogether for the calculations (I have no idea how to calculate the friction at the moment anyway... We only just started the concept of forces recently in class. This problem was given to us before that chapter). We just need to find the height of the ramp, there's no need to over-complicate it.
But anyway, I'm still confused on what mfb was saying.
I found h to be:
h = 4.25t2*Sin(30)
But I'm not sure how to proceed from here.
You need to find the velocity as it leaves the ramp, and for that the accelerations are those that apply all along the ramp.
How many times do I need to ask you to write out the force/acceleration equations?
How would I figure out the force? The problem didn't give a weight. Fnet = ma would leave me with two variables again.
Don't worry about the mass. Let it be m. It will cancel out later.
Your force diagram is wrong. Which way does the normal force act? There's no friction, so forget Fs (and anyway it would have been Fk). What's Fslide??
Sorry, I just recently started on forces. This new diagram should be correct, having no friction. Just Fn and Fg. -- The Fslide on the old diagram was just a mistake. I forgot that there are no forces acting on it since there are no forces which are physically touching the object (unless it's a long-range force).
Fnet = ma
Fynet = m(gSin(30))
Fxnet = m(gCos(30))
Is this correct? I'm not sure since you said gSin(30) & gCos(30) wasn't the acceleration... I don't know the force nor the mass to figure out acceleration if I needed to otherwise.
Shaku said:
Fynet = m(gSin(30))
Fxnet = m(gCos(30))
The diagram is right now but those equations do not spring from it at all. What happened to the normal force? How does g get a horizontal component?
Let's try it again, one step at a time:
- what is the component of Fn in the vertical direction?
- what is the component of Fn in the horizontal direction?
- what is the component of Fg in the vertical direction?
- what is the component of Fg in the horizontal direction?
  • #31
Do you know what the answer should be?
  • #32
Btw, neglecting air drag should have been mentioned in problem statement.
  • #33
9.8 (Since Fn is opposite of g).
I'm not sure... since you said this wasn't gCos(30), but that's the only way I see that I can get this force.
-9.8 (gravity)
Edit: At the bottom it says "in the downward direction"
Edit2: Just realized my math was wrong for Fnety.
Should be:
9.8Sin(30) - 9.8 = 4.9.
Edit3: Also just realized this doesn't work either... It just = 9.8 again... Sigh. I need help ><
Sadly, no.
This problem was given to us before any force concepts were introduced, so it was assumed that air drag is neglected.
  • #34
The acceleration will have a vertical component, so you can't assume the forces balance. At this stage, I'm not asking you to equate forces. My question is much simpler: if the normal force is Fn, and the slope is 30 degrees, what is the component of Fn in the vertical direction?
Similarly my other questions.
  • #35
In that case it would be:
Fny = FnSin(30) (Since slope is Fn, angle is 30, and we're looking for the opposite)I was talking to a friend earlier today, and he said that the force at the end of the ramp would be gTan(30), and then you'd use that to somehow work out the problem. I'm still completely lost though...
If he's correct, then Fny = gTan30*Sin(30)... But that seems like a really small force (~0.28867 Newtons), so I doubt that's correct.
  • #36
There is no tangens involved in the problem.
  • #37
There's a useful check you can do on whether you have chosen correctly between sine and cosine. What if we change the angle to 0, so that the ramp is horizontal? If it's sine, that would make the vertical component of the normal force zero. Does that seem right?
  • #38
So, in my diagram (I know I drew it wrong, just imagine the red triangle is touching the slope. The slope is the X axis, and perpendicular is the Y axis), you're saying that the vertical component Fny is FnCos(30)? SohCahToa - Shouldn't it be Sin since we have the hypotenuse and are looking for the opposite angle (which is the vertical component of Fn)?
Why is it that it's FnCos(30) and not FnSin(30)? I may just be picturing this wrong, but if we use FnCos(30), wouldn't we be finding the horizontal component instead of the vertical component?
  • #39
It's called the normal force because it is normal to (i.e. perpendicular to) the surface. You're drawing it at an angle of 60 degrees to the surface.
  • #40
Ohhhhh, that clarifies things a lot!
It would be like this:
What do I do next?
  • #41
Good. Now have another go at the horizontal and vertical components of the two forces.
  • #42
FnCos(30)
FnSin(30)
mg
  • #43
FnCos(30)
FnSin(30)
-g
Yes! (Well, almost: should be mg, not g.)
Next, we have to relate these to acceleration. Suppose the acceleration down the ramp (i.e. parallel to the ramp) is a. What are the vertical and horizontal components of that acceleration? What equations can you then write down relating these to the four force components above?
  • #44
Ah, you're right; I forgot about the mass there.
a = Fnet/m
So vertical acceleration is:
ay = (FnCos(30)+g)/m
and horizontal acceleration is:
ax = FnSin(30)/m
thus the acceleration is:
a = ((FnCos(30)+g)/m) + (FnSin(30)/m))
  • #45
The normal force and the gravitational force are in almost opposite directions. Which direction (up or down) are you taking as positive? Also, you've dropped the m from mg again.
  • #46
g = -9.8 as in down is negative
(I changed it to -g below for clarification)
and oops!
a = Fnet/m
ay = (FnCos(30)-mg)/m
ay = (FnCos(30)/m) - g
ax = FnSin(30)/m
[STRIKE]a = ((FnCos(30)/m) - g) + (FnSin(30)/m))[/STRIKE]
  • #47
ax = FnSin(30)/m
Yes.
No, that's not how you add vectors.
Next, we need to make use of the fact that we know which direction the overall acceleration will be in: down the ramp. This tells us the ratio of the two acceleration components. Can you see how to do that?
  • #48
So, it would be:
a = \sqrt{(((FnCos(30)/m) - g)^2 + (FnSin(30)/m))^2)}
So how I do I find the acceleration in terms of an actual number once I have this?
  • #49
Shaku said:
So, it would be:
Yes, but as I said, the next step is think about the ratio between the horizontal and vertical accelerations. Or equivalently, if a is the nett acceleration down a ramp at 30 degrees, what would its horizontal and vertical components be?
  • #50
ay = Sin(30)*\sqrt{(((FnCos(30)/m) - g)^2 + (FnSin(30)/m))^2)}
ax = Cos(30)*\sqrt{(((FnCos(30)/m) - g)^2 + (FnSin(30)/m))^2)}
