MHB What is the slope and intercept in slope-intercept form?
  • Thread starter Thread starter TheLibraSign
    Form
Slope-intercept form is represented by the equation y = mx + c, where m is the slope and c is the y-intercept. Understanding this form is crucial for working with scatter plots and lines of best fit, as it lays the foundation for more advanced mathematical concepts. For example, if a line has a slope of -3 and passes through the point (2, 12), the y-intercept can be calculated to find the complete equation. A video from Khan Academy provides further explanation on this topic. Mastering slope-intercept form enhances comprehension of linear equations and their applications in various mathematical contexts.
TheLibraSign
I never quite understood slope-intercept form, my math teacher never really explained it too well. And so it kind of affects almost everything else I do. Like the scatter plots and lines of best fit sort of thing.
And all the more advanced stuff I never understood when I was in advanced classes.
Mathematics news on Phys.org
Are you familiar with writing linear equations any other way? For example $$ax+by+c = 0$$
Here's a video from Khan Academy about slope-intercept form.
Slope-intercept form is an equation in the form $$y = mx + c$$.
$$m$$ is the slope of the line and $$c$$ is the y intercept (shortened to intercept in the title).
Suppose you have the line $$y = x+1$$ which looks like this). The slope is 1 and the intercept is also 1.
For a different example suppose you know the slope of a line is -3 and it passes through the point (2,12). Immediately you can tell that $$m = -3$$.
To find the intercept you can plug in x=2 and y=12 into your equation and find $$c$$ -- $$12 = -3(2) + c \ \rightarrow c = 18$$
Thus the equation is $$y = -3x + 18$$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
