Solar panel and regenerative braking system
11 replies · 5K views · last reply
huzzi.123
For my ongoing project, I'm thinking of using Solar panels and Regenerative braking system as two main sources to charge the batteries that will run the motor and in turn the accessories of the car.
I've to think of how can the above sources increase the overall efficiency of the car?
1) The use of battery pack can reduce the overall weight of the car and thus decreases the aerodynamic drag.
2) Using solar energy as an alternative to non-renewable resource such as petroleum that means the car won’t emit dangerous gases while using solar power to run the accessories.
Wondering if the above statements sound legit?
They sort of sound true, but on closer inspection ...
1) the battery pack gives a reduction in weight in comparison to what alternative??
2) minimizing dangerous gases may be true, but hasn't been of concern to most petrol-engine drivers all these years---except in mine shafts and enclosed spaces such as inside buildings and refrigerated storage sheds. Oh wait, you are talking about having to run the engine to power, say, the aircon while parked?
reduction in weight compared to regular combustion engine cars
but it still sounds technically correct? Because all I'm concerned about is increasing the efficiency of a car
You should probably start by defining what you mean by "efficiency"
Miles per Gallon
Energy out/Energy In?
$ per mile?
The fuel for a solar powered car is free so would that mean you consider a solar powered car infinitely efficient? On the other hand batteries are expensive and wear out. Currently they add a lot to the running cost of an electric car.
Miles per Gallon
$ per mile?
Efficiency in the sense that it can overcome the losses mentioned in the link below:
http://www.consumerenergycenter.org/transportation/consumer_tips/vehicle_energy_losses.html
Weight is not listed in the equation for drag, and therefore, has no effect.
from wiki:
FD = 1/2 ρ v2 CD A
FD is the drag force,
ρ is the density of the fluid
v is the speed of the object relative to the fluid
A is the cross section area
CD is the drag coefficient – a dimensionless number.​
Electric cars are being constructed to be smaller than most petrol-engined cars, but these small production electric cars can't cruise the non-stop distance of their petrol rivals on one "tank". Their advantages lie elsewhere.
Lighter weight means less energy is needed to get the vehicle up to speed and up hills.
Makes sen
Makes sense. But does solar car with (regenerative braking system) help reduce idling losses (when it is not running) or any engine losses?
If you're talking about a hybrid electric-gasoline vehicle, and the gasoline engine is not running, due to the start-stop technology listed in http://www.consumerenergycenter.org/transportation/consumer_tips/vehicle_energy_losses.html earlier
Idling Losses - 17.2 percent
In urban driving, significant energy is lost to idling at stop lights or in traffic. Technologies such as integrated starter/generator systems help reduce these losses by automatically turning the engine off when the vehicle comes to a stop and restarting it instantaneously when the accelerator is pressed.
then the gas engine losses are zero. As long as you don't count the energy required to restart the gasoline engine.
Which from some guy at car talk:
I'd say current draw 50 amps (small, warm 4 cylinder) to 300 amps (cold V8) at 12V. That works out to 600 to 3600 watts. Then, it might take 0.5 second to start a warm, well tuned motor and 5 seconds to start a cold, finicky motor.
So my answer is 300 to 18000 watt-seconds (joules). More for a diesel and/or very large motor
varies quite a bit.
But if you have 750 watts worth of solar panels on your roof, that range of energy can be collected in between 1/2 second to 1/2 minute.
As for your idea in general, I like it a lot. I know a guy who's alternator broke just as he was leaving work one day. Instead of spending $100+ bucks to get towed home, he temporarily installed 150 watts worth of solar panels to his car. Believe it or not, it worked. The trip was about 13 miles, and took about 30 minutes.
Photo of a red car's open trunk with a large blue photovoltaic solar panel mounted on a rack over the luggage area, with a silver car parked behind it.
Of course, it was a sunny June weekend day when he did this. Had it been a typical November cloudy weekday during rush hour, he would have called a tow truck.
ps. He has since replaced the car. It was the mother of all lemons. It was towed home on two other occasions, and should have been two more times. But the guy is a bit of a nut.
varies quite a bit.
Photo of a red car's rear deck with a large rectangular solar panel mounted on top of the open boot, with a silver car visible behind it.
Sounds good but doesn't electric motor needed to run a car? So solar panel will charge the batteries and batteries will in turn run a motor to convert electrical to mechanical energy. I haven't done much research on hybrid electric cars but do you think the idea I'm talking about refers to hybrid electric cars? I heard that regenerative braking system comes into play when the brakes are applied, the heat generated is converted into electrical energy so engine turns off and energy is saved but I was wondering if solar panel can contribute something to overcoming the losses mentioned in my link before?
It's your job to tell us what you are designing. A pure electric car will either be expensive and have a decent range, or cheap and almost no range. I calculated last week that a battery with a range of 25 miles would cost $5000. A hybrid car like the Chevy Volt is in my opinion a very well matched system. It has a range of 35 miles in full electric mode. The average American between the age of 20 and 55 drives 41 miles per day, on average. (ref) I think you could probably outfit a Chevy Volt with 500 watts of panels, which if you left it in the sun for 8 hours, would generate 4 kWh of energy. Since the battery pack is 16 kWh, you can interpolate the "miles per kWh " as being roughly 2 miles per kWh. So 4 kWh will power the car for about 8 miles.
I'm not aware of any regenerative braking systems that convert heat into electricity. That would be very inefficient. They use generators to slow the vehicle while simultaneously charging the battery pack.
In a gas-electric hybrid, yes.
Yes. A solar panel will collect energy, which will either charge the battery, or run auxiliaries.
To my mind it makes little sense to put solar panels on a general purpose electric car. The amount of power you can collect on a trip will be very small compared to the amount you need to make a typical trip. Much better to use the space and weight that the solar panels would occupy to fit a slightly bigger battery. Build a much larger array of solar panels at home/work or some field to charge it.
Regenerative brakes don't convert the heat produced by conventional brakes. Many electric motors (such as those used to power an electric car) can be used "in reverse" as generators - so adding regenerative braking to an electric car might not add any significant weight just a bit of complexity to the motor control system.
