Solution of "polynomial" with integer and fractional powers
The discussion revolves around solving a polynomial equation involving both integer and fractional powers, specifically the equation x + a(x^2 - b)^(1/2) + c = 0. The initial approach involves substituting a new variable to transform the equation into a standard polynomial form, but challenges arise when fractional powers appear in the new polynomial. A suggested method includes eliminating the radical by manipulating the equation, which leads to a quadratic form that can be solved more easily. The participant is seeking guidance on finding an effective change of variable for a more complex equation they are working on. Overall, the conversation highlights the difficulties of handling fractional powers in polynomial equations and explores strategies for simplification.
idmena
Hello, I have a question regarding "polynomials" that have terms with interger and fractional powers.
I want to solve:
$$ x+a(x^2-b)^{1/2}+c=0$$
My approach is to make a change of variable x=f(y) to get a true polynomial (integer powers) that I know how to solve, e.g.:
$$y^2+a y +b =0 $$
Then I can switch back from y to x and use each of the solutions in y to get solutions in x. I find that works ok when the power of x inside the root is lower or equal than the power of x outside the root, for example, for the following equations:
$$ x+a(x-b)^{1/2}+c=0 $$
$$ x^2+a(x-b)^{1/2}+c=0 $$
$$ x^2+a(x^2-b)^{1/2}+c=0 $$
the solution is given by making the replacement: ##y=(x^n-b)^{1/2}##, then you have a polynomial in y, e.g.: ##y^2+ay+(b+c)=0## which is straightforward.
If I try the same on this one I get a fractional power of y in the new polynomial, which puts me back in square 1. So far I have not been able to find the right change of variable for this problem.
I am trying to work my way up to:
$$ a x + b x^2 + c x^3 + d (e+fx+(g+hx+jx^2)^{1/2})^2 =0$$
which is the actual equation I need to solve in the problem I am working on.
Any hints?
Thank you!
The way that I would do it is to try to get rid of the radical. For the simple example:
x + a\sqrt{x^2 - b} + c = 0 \Rightarrow x+c = - a \sqrt{x^2 - b} \Rightarrow x^2 + 2cx + c^2 = ax^2 - ab
Likes idmena
Of course, it's evident!
Thank you for your prompt answer.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
