Solve 3rd order ode using variation of parameters
2 replies · 6K views · last reply
abstracted6
Solve using variation of parameters
y''' - 2y'' - y' + 2y = exp(4t)
I got the homogenous solutions to be 1, -1, and 2.
So, y = Aexp(t) + Bexp(-t) + Cexp(2t) + g(t)
I got W{exp(t), exp(-t), exp(2t)} = 6exp(2t)
My professor did quite an unsatisfactory job explaining variation of parameter for high order equations (spent an hour and 30 minutes trying to do 1 problem, and still didn't finish it correctly). So I just need to be pointed in the right direction.
Thanks
Actually, I got -6 exp(2t), but maybe I made a sign error in my calculation.
So the general idea is now to replace the ith column in the matrix by (0, 0, exp(4t)) and calculate the determinant |Wi| of that, for i = 1, 2, 3.
Then if you calculate
[tex]c_i(t) = \int \frac{|W_i|}{|W|} \, dt[/tex]
the general solution is
[tex]y(t) = c_1(t) e^{t} + c_2(t) e^{-t} + c_3(t) e^{-4t}[/tex]
As a learning exercise, fine. But I assume you know nobody in their right mind would use variation of parameters to find a particular solution, eh?
