Solve a Quadratic Equation with Vertex Form
  • Context: MHB
  • Thread starter Thread starter catwalk
    Points Stuck
The discussion revolves around solving a quadratic equation in vertex form, specifically focusing on the concept of "best fit" and how to derive the parameters a, h, and k from given data points. Participants explore methods for estimating values and applying regression techniques.
  • Homework-related
  • One participant expresses uncertainty about how to convert a quadratic equation to vertex form and what points to use.
  • Multiple participants inquire about the meaning of "best fit" and suggest that there are different interpretations or methods associated with it.
  • Suggestions are made to look up "best fit" in textbooks or online resources for clarification.
  • Another participant provides a list of x-values for data points and recommends estimating corresponding y-values, followed by using an online quadratic regression calculator.
  • A detailed method is proposed for determining the parameters a, h, and k using three specific data points, including the formulation of equations based on those points.
  • A more complex approach involving the least squares method is introduced, which aims to minimize errors across all data points rather than just three selected points.
Participants do not reach a consensus on the best method to approach the problem, and multiple competing views on how to interpret "best fit" and derive the quadratic parameters remain present.
Some participants highlight the need for clear definitions and instructions regarding "best fit," indicating potential limitations in understanding the problem due to a lack of guidance.
catwalk
I know this is the equation I have to use a(x - h) 2 + k, but don't know what points to use and how to covert to vertex form
Mathematics news on Phys.org
Do you know what "best fit" means? There are several different types of "best fit". Which have you learned?
No, I am not even sure what best fit means. I guess whatever is the simplest
Where did you get this problem? Did some evil teacher assign a problem about "best fit" without giving any instruction related to that?
(Don't you just hate when they do that?)
Have you tried looking up "best fit" in your textbook or online?
Haha yeah that's what happened.
I've looked online but still don't know what to do
The x-values of each data point seem to be easy ... 0, 2, 4, 5, 7, 9, 10, 12, and 14
You’ll just have to make your best eyeball estimate for the y-values.
Once you get a reasonable list of coordinates, do a google search for an online quadratic regression calculator and see what that can do for you.
Since you say you want a quadratic of the form a(x-h)^2+ k (notice the "^" for the exponent. That's clearer than just "x2".) You need to determine a, h, and k, three numbers. For that, you need three equations. The simplest thing to do is to choose three "data points" to get those equations. I recommend three widely spaced points so as not to exagerate any "anomaly" (like those two successive points with almost the same y which cannot happen in parabola). To the far left we have (0, 0), in the center, (7, 350), and on the right, (14, 80). In order that the parabola pass through those points we must have a(0- h)^2+ k= ah^2+k= 150, a(7- h)^2+ k= 350, and a(14-h)^2+ k= 80. Solve those equations for a, h, and k. Subtracting the first and third equations from the second eliminates "k" giving a(7- h)^2- ah^2= 200 and a(7-h)^2- a(14- h)^2= 270. Calculating the squares we have 49a- 14ha+ ah^2- ah^2= (49- 14h)a= 200 and 49a- 14ah+ ah^2- 196a+ 28ah- ah^2= a(14h- 147)= 270. Divide the second equation by the first to eliminate a, (14h- 147)/(49- 14h)= 270/200 and solve that equation for h.
A more "sophisticated" method would the "least squares" method which is harder but uses all of the data. With y= a(x-h)^2+ k, for each data point (xi, yi) the "error" is yi- a(xi- h)^2- k, the difference of the data value and the computed value. For example, for the first ^data point, (0, 0) the "error" is 0- a(0- h)^2- k= -ah^2- k. For (7, 350) the "error" is 350- a(7- h)^2- k. If we were to simply add those we might have a negative error cancelling a positive error that we do not want to happen. So square each and then sum. To find the smallest possible error, take the derivative of that sum of squares with respect to a, h, and k and set the derivatives equal to 0. Again that gives three equations to solve for a, h, and k.
  • · Replies 44 ·
