Solve Bounded $u_t=u_xx$ Let $u_t=u_xx,\,t>0,\,x\in\mathbb R$
  • Context:
  • Thread starter Thread starter Markov2
    Bounded
3 replies · 3K views
Markov2
Let $u_t=u_xx,\,t>0,\,x\in\mathbb R$ and $u(x,0)=xe^{-|x|}.$ Show that $|u(x,t)|\le \dfrac K{\sqrt t}$ for all $t>0$ and $x\in\mathbb R$ where $K$ is a constant.
So I apply Fourier transform, then $\mathcal F(u_t)=\mathcal F(u_xx)$ then $\dfrac{{\partial \mathcal F(u)(w,t)}}{{\partial t}} = - {w^2}\mathcal F(u)(w,t)$ so $\mathcal F(u)(w,t)=ce^{-w^2t}$ then $\mathcal F(u)(w,0)=c=xe^{-|x|},$ is the initial condition well put? I'm not sure really, I'm confused.
on Phys.org
Since you have a representation formula for \(u\), everything's easier. You have
$$u(x,t)= \frac{1}{\sqrt{4\pi t} } \int_{\mathbb{R}} e^{\frac{(x-y)^2}{4t}}g(y)dy$$
This gives, using Hölder's inequality with \(p=1, p'=\infty\)
$$|u(x,t)|\leq \frac{1}{\sqrt{4\pi t} } \int_{\mathbb{R}} |g(y)|dy$$
since \(\sup_x e^{\frac{(x)^2}{4t}} = 1\) for all \(t>0\).
Could you please show me how did you find $u(x,t)$ ? I'm stuck on the initial condition, don't know if I did it right, can you check?
I won't write out everything, since apparently my definition of the Fourier transform is different (non-essentially though) from yours. You should arrive at an equation of the form \(\hat{u}_t (x,t)= c(x)\hat{u}\) (\(c(x)\) will depend on your definition of the transform) with the initial condition \(u(x,0)=\hat{f}(x)\) (where \(f\) is your initial condition). This has a solution given by \(\hat{u}(x,t)=\hat{f}(x) e^{c(x)t}\). Put the exponential as the Fourier transform of someone and apply the result that says the transform of a convolution is the product of the transforms along with the inversion theorem. This should give you my formula.
