Solve Calculus Problem: Find a & b from f(x) and Tangent Line at (a,b)
The problem involves finding the values of a and b for the function f(x) = x^3 - x^2 - 4x + 4, where the point (a,b) lies on the graph of f and the tangent line at that point passes through (0,-8). Participants are exploring the relationships between the function, its derivative, and the tangent line.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss setting up equations based on the function and its derivative, with attempts to express b in terms of a. There are questions about the complexity of the problem and whether it aligns with typical expectations for similar homework tasks.
Some participants have provided hints to simplify the equations and suggest visualizing the problem. There is an acknowledgment of the difficulty of solving cubic equations, and while some participants express confidence in their approaches, others question the number of potential solutions.
Participants note that the problem is part of an AP free response question, raising concerns about the time required to solve it. There is also discussion about the possibility of multiple solutions to the cubic equation derived from the problem.
cdhotfire
This somehow seems easy, but I cannot get the jist of it.
The point (a,b) is on the graph of f and the line tangent to the graph at (a,b) passes through the point (0,-8) which is not on the graph of f. Find the values of a and b.
okay so, I've spent about an hour just on this part, this problem had 3 parts.
so i though, maybe, set the original with as and bs, so:
b= a^3 - a ^2 - 4a + 4
then maybe take the derivative
b'= 3a^2 - 2a - 4
so maybe
y-8=b'x
from there on it seems to get pretty nasty, doesn't seem like the type of problem, that should be this nasty.
maybe someone can shed some light on this.:smile:
thanks in advanced.:-p
You are actually very close. You should be able to expand your last equation and get it in terms of only a and b. Same with the first one. You end up with 2 equations in 2 unknowns (I think). Hint: the point (a,b) is on the graph of each function.
Also, if you haven't already, it really helps to draw a picture. You don't have to actually plot the function, just draw a function, pick a point, draw a tangent to it, etc.
hmmm, so
b = 3a^3 - 2a^2 - 4a - 8
b = a^3 - a^2 - 4a + 4
0=-2a^3 +a^2 +12
yuck, I am sure this wasnt suppose to happen. :(
edit: somehow, i think I am making it harder than it seems, looks like a very simple problem. :\
Can't you solve the last equation for a? I got it just by staring at the equation for a few minutes.
hotvette said:
Can't you solve the last equation for a? Cubics are rarely easy.
a= (-6/a^2) - (1/2)?
i don't know, seems like this question could take up a long, long time. this is supposedly an ap free response question. I am thinking this question, is a little too long, to be on a timed test.
Much easier than that. Just look at the equation and try to imagine what values of a will satisfy the equation. The first one I tried was the right one.:smile:
so i put in 2, get 4x^2 + 3x +6, looks like a mr quadradic to me.
edit: roar!, mr quad come out a bad choice.
so only one answer? (2,0)?
[tex]0=-2a^3 +a^2 +12[/tex]
This is the one you are trying to solve for a. I like the choice you made.:smile:
so (2,0) is the only answer?
The question was to find a & b, which you just did. Congratulations!
http://img.mauj.com/an/b/BowingSmiley.gif
thank you. very much. :)
spent 2 hours on this and its late, time for sleep. thanks again.:smile:
Sorry I didn't have a more thoughtful answer (I needed my beauty sleep :biggrin:). Since you wanted (a,b) to satisfy the 2 equations, you could claim that you are done since you found that. But, you are curious (which is good) that there might be more solutions to [itex]0=-2a^3 +a^2 +12[/itex] since it is a cubic. Good point. You have several options. My first choice is to go ahead a plot it (don't think that's against the rules). Sure enough, there is only 1 real root. So, the other 2 must be? Actually, if there were more than 1 real root, that would mean that a line passing through (0,-8) would be tangent to the function at more than 1 point (i.e. multiple a,b combinations). See attached thumnail illustrating the situation.
  • · Replies 33 ·
