Solve Differential Equation with Euler's Method
The discussion revolves around solving a differential equation using Euler's method, specifically focusing on both explicit and implicit approaches. Participants are exploring the conditions under which these methods are applicable and stable, as well as discussing the implications of the damping coefficient.
  • One participant presents the differential equation dy/dt = -lambda * t * y(t) with the initial condition y(0) = y0, seeking assistance in solving it using Euler's methods.
  • Several participants question the formulation of the damping coefficient lambda and its role in the equation, suggesting that it may not align with typical definitions of damping coefficients.
  • Another participant outlines the explicit and implicit forms of Euler's method, providing equations for both approaches and seeking agreement on these formulations.
  • Concerns are raised about the stability of the explicit Euler method, with one participant noting that certain values of delta t lead to instability, indicating a need for careful selection of parameters.
  • There is a request for clarification on the differences in results between the implicit and explicit methods, as well as inquiries about the errors associated with each method compared to the exact solution.
  • Participants express confusion regarding the progress on the first part of the exercise, with some indicating they have not seen a complete solution yet.
Participants generally agree on the need to clarify the formulation of the differential equation and the methods to solve it. However, there are multiple competing views regarding the stability of the methods and the appropriate choices for parameters, indicating that the discussion remains unresolved.
Participants have not yet reached a consensus on the correct formulation of the damping coefficient or the stability limits for the Euler methods. There are also unresolved questions about the specific results obtained from the methods applied.
youcef
Hi evry body
i would like to have an help to resolve this exercice below
the followin differential equation with its initial condition
dy/dt=-lambda t y(t) t>=0
avec y(0)=y0
where lambda is damping coeficient strictly positive.
-find the solution of this equation with Euler's explicite and implicite methode
-find analytically the values of h in order to euler methode (explicite) being applicable and obviously stable ( lim IynI=0 where n --->infini .and find the superior borne of time lag h according lambda>0
thanks
warmest Regards
Hello youcef, bienvenu a PF :smile: !
$${dy\over dt } = - \lambda \, t \, y(t) \\
y(0) = y_0$$ is what you want to solve ? Or have to solve (in that case it should be in the homework section!)
Or is it ## -\lambda(t) \, y(t) ## or is it just ##- \lambda \, y(t)## ?
What would make ##\lambda## a damping coefficient ? (I am used to damping coefficients in forms like ##{d^2y\over dt^2 } = - \lambda \, { dy\over dt}\ ## so I thought I'd better ask first.)
Thanks
y(0) = y_0$$
OK, so let's get started on the first part: for Euler explicit you get $$ { y_{k+1}-y_k\over \Delta t} = -\lambda \, t \, y_k $$ and for Euler implicit you have to solve $$
{ y_{k+1}-y_k\over \Delta t} = -\lambda \, t \, y_{k+1}
$$to get ##y_{k+1} ## as a function of ##y_k##, ## t##, and ##\Delta t##.
Agree ?
Thanks BvU .I Agree.let's continue
Well, where do you have a problem when you do continue ?
Wow, I don't follow. Is this for explicit Euler ?
So how do you come from $$
$$ to your ...(1) ? I don't see a square appearing at all !
sorry
for implicite method yk+1=yk/(1+Δtλt)
for explicit
yk+1=yk(1-Δtλt)
What happened to your post ? If you edit it away completely, no one else can follow the thread later on !
for implicit method yk+1 = yk / (1 + Δt λ t )
for explicit yk+1 = yk (1 - Δt λ t )
Good. Any further problems ? If not then part one is ready ?
BvU said:
What happened to your post ? If you edit it away completely, no one else can follow the thread later on !Good. Any further problems ? If not then part one is ready ?
you are very kind .yes no problem.let's go to second part
IF part 1 is ready, then what does your solution look like ? Any differences between implicit and explicit methods ?
Do you know the error both methods give when compared to the exact solution ?
What choices of delta t and lambda did you make ? I tried lambda = 0.5 and delta t up to 0.5 (0.501 went bang for the explicit Euler...)
But in fact the stability limit is exceeded a lot earlier. 0.32 also crashes
i don't understand what do you mean.is that is wrong solution
So far, I haven't seen your solution of the differential equation, so I don't know...
good morning
so anyone can't resolve it?
youcef said:
good morning
I don't understand. How far are you really with part 1? What results do you have to show ? See questions in post #11
I have no idea if yes i do it by my self.
