Solve du/dt=Pu when P is a projection
  • Thread starter tatianaiistb
    Projection
6 replies · 6K views · last reply
tatianaiistb
Solve du/dt=Pu when P is a projection.
[1/2 1/2 = du/dt with
1/2 1/2]
[5 = u(0).
3]
Part of u(0) increases exponentially while the nullspace part stays fixed.
du/dt = Au with u=u(0) at t=0
I'm stuck with this problem. I was thinking that u(t)=eλt*x.
Would du/dt be considered matrix A? Thanks!
1/2 1/2]
[5 = u(0).
3]
I don't understand much of what you have written.
Is this P?
[1/2 1/2]
[1/2 1/2]
If so, it's not a projection matrix - it is just 1/2 I, the identity matrix.
du/dt is a two-dimensional vector, whose components are du1/dt and du2/dt.
Your system of differential equations, not written in matrix form would look something like this:
du1/dt = a11u1 + a12u2
du2/dt = a21u1 + a22u2
This could be written in vector/matrix form as du/dt = Au.
That's where I'm confused at.
[1/2 1/2 = du/dt. So I guess this means that the matrix equals Pu.
1/2 1/2]'
I'm not sure what to make of the matrix.
Hi tatianaiistb! :smile:
[1/2 1/2]
[1/2 1/2]
is the matrix for the orthogonal projection on (1,1).
(Sorry Mark :redface:)
So with u(t)=(x(t), y(t)) the problem reads:
[tex]\begin{align}\dot x ={1 \over 2}x + {1 \over 2}y \\ \dot y ={1 \over 2}x + {1 \over 2}y\end{align}[/tex]
with
[tex]\begin{align}x_0 = 5 \\ y_0 = 3\end{align}[/tex]
Can you solve that?
Thank you both... I think I figured out the problem. I greatly appreciate it!
I like Serena said:
[1/2 1/2]
[1/2 1/2]
No problem and no need for apology. I wasn't able to make heads or tails out of what she was trying to do, so I'm glad you jumped in.
