Solve for Pump Horsepower in 1-Inch Tube with No Heat Transfer
The discussion focuses on calculating the horsepower required for a pump moving fluid through a 1-inch diameter tube, with given parameters of fluid density, flow rate, and pressure rise. The first law of thermodynamics is referenced, with the assumption of no heat transfer, leading to the conclusion that the change in enthalpy relates directly to the pressure and volumetric flow rate. Participants express confusion about unit conversions and the application of fluid dynamics principles, particularly in determining the velocity and power output. The calculation involves converting pressure from lbf/in to psf and using the relationship between horsepower and the rate of doing work. Ultimately, the solution requires careful consideration of the fluid's properties and the pump's efficiency.
MonkeyMouse
This was a thermodynamics question;
A fluid is being moved by a pump though a 1inch diameter tube. The density is 100 lb/ft3 with a flow of 12 lb/s. The pressure rises 40lbf/in. Assume there is no heat transfer. Find hp of the pump to the nearest 1/4hp.
I assumed that the first law of thermodynamics was needed:
0=Qcv-wcv+m[(h1-h2)+(V12-V22)+g(z1-z2)]
I assumed Q=0 but was rather confused on how to even start this equation. I believe you would need to use density relations to find the specific volume and enthalpy in order to apply the 1st law of thermodynamics? Would this be better suited to be solved in terms of fluid dynamics?
It is said that, flow is 12 lb/s
So you can calculate the speed after the pump (you have diameter of the tube too)There is nothing about the speed before the pump, so we can assume it is zero.
Nothing is said about any diference in height of input/output too.
So
(z1-z2)=0
and because
and
you can easy calculate the power
η has to be 1, because it is said, there is no heat transfer
http://en.wikipedia.org/wiki/Pump
Likes 1 person
Still pretty stuck, I am unsure how to get the change in P into psf from the units had once I incorporate the velocity?
What is the volumetric flow rate? Neglect the temperature rise. The rate of doing shaft work is equal to the rate of change of enthalpy for the mass going through the pump. Since there is no temperature change, it is just ΔP times the volumetric flow rate.
So just (5760lb/ft^2)(.12ft^2/s)... how would I get hp from those units?
1HP is 550 ft-lbs/sec.
Likes 1 person
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
