Solve for ##x## involving modulus
10 replies · 3K views · last reply
brotherbobby
Solve ##|x|+|x-2|=2##
1. For a given function ##f(x)##, if ##|f(x)|<a \Rightarrow -a < f(x) < a##
2. For a given function ##f(x)##, if ##|f(x)|>a\Rightarrow f(x)<-a\; \text{or}\; f(x)>a##
(I could solve the problem but could not make sense of the solution given in the text. Let me put my own solutions below first).
Printed equation: Solve |x| + |x - 2| = 2.
1. Problem Statement :
I copy and paste the problem to the right as it appears in the text.
2. My attempt : There are three "regions" where ##x## can lie.
(1) ##\mathbf{x \ge 2}## : In this case we have given ##|x|+|x-2|=2\Rightarrow x+x-2 = 2\Rightarrow 2x=4\Rightarrow \boxed{x=2}## (as the answer ##x=2## lies within the selected range in which the equation is solved).
(2) ##\mathbf{0\le x<2}## : For this case, the equation: ##|x|+|x-2|=2\Rightarrow x+2-x = 2 \Rightarrow 2=2## which is always true. Hence the selected range is a solution : ##\boxed{0\le x<2}##.
(3) ##\mathbf{x<0}## : In this case, the given equation : ##|x|+|x-2|=2\Rightarrow -x+2-x = 2\Rightarrow 2x=0\Rightarrow x=0##. This solution has to be rejected for it doesn't lie in the selected range.
Hence, the solution to the problem : ##\boxed{0\le x\le 2}##. ##\Large{\checkmark}##, as it agrees with the answer in the text.
Handwritten solution: |x| + |x-2| = 2 implies |x| + |x-2| = x - (x-2) (step 1, marked in red), implies x(x-2) ≤ 0 (step 2), implies 0 ≤ x ≤ 2.
3. The text's attempt :
I copy and paste the solution in the text given to the right.
It is the solution that I am struggling to follow. Namely on the two steps marked as 1 and 2.
In 1, the author is tacitly assuming that ##x>0## and that ##x<2##. What is the reason for this assumption? There are three broad regions where ##x## can lie, as I have shown in my solution above. Why take the one on the middle, as he has done?
2 is more confusing. How can the expression ##x-(x-2)=2## become ##x(x-2)\le 0##?
A hint or suggestion referring to the author's solution would be welcome. I admit that he obtains the same answer as I do.
I wouldn't particularly worry about the text solution as yours is better.
Note that the one-way implication given in the text is not enough. It needs two-way implication.
Re your first question, the author has replaced the ##2## on the RHS by the equivalent ##x - (x -2)##.
@PeroK said how (1) result. For the (2), just square both sides of (1). After simplifications you ll get $$|x||x-2|=-x(x-2)\iff |x(x-2)|=-x(x-2)$$
Ahh how silly of me. Yes indeed ##2 = x-(x-2)##, as an identity, independent of the problem. The author's solution not only makes sense but is superior to my own. Let me explain.
But first, I forgot to mention something in the Relevant Equations. That ##|x|+|y| = |x-y|##, if ##x## and ##y## are of opposite signs. Or one of them can be zero.
Attempt :
\begin{equation*}
\begin{split}
|x|+|x-2|&=2\\
& = |2|\\
&=|x-(x-2)|\\
\Rightarrow x(x-2)&\le 0 \mathbf{*}\\
&\Rightarrow\boxed{0\le x \le 2}
\end{split}
\end{equation*}
* Since the line above implies that (x) and (x-2) must be of opposite signs, referring to my Relevant Equations.
A simple approach is to draw a graph of the function ##|x| + |x-a|## and note that it has a constant value of ##a## in the interval ##[0,a]## and linear on either side.
That also solves the more general problem of ##|x| + |x-a| = b##.
ehm was that a typo you meant to write the more general problem ##|x|+|x-a|=a##?
No, the general case where ##a \ne b##.
Hmm, if ##b\neq a## then it has at most two solutions right? Not an interval of solutions.
Yes. My point was really if we draw a graph of the function, then all is clear.
It is necessary that the solutions lie in said interval. Conversely, given any ##x\in [0,2]## one readily verifies it satisfies the equality.
