Solve Friction Problem: Max Force on 1.0 kg Block
  • Thread starter Thread starter Fusilli_Jerry89
    Friction
9 replies · 2K views
Fusilli_Jerry89
A 0.5 kg mass is on top of a 1.0 kg mass on a table. The static coefficient of friction between the blocks is 0.35, and the kinetic coefficient of friction between the table and1.0 kg block is 0.20. What's the maximum force that can be applied horizontally to the 1.0 kg block without letting the 0.5 kg block slip?
the acceleration of the small block has to be zero, so the friction between the two blocks cannot exceed 1.715 N.I got the equation for the first blockdown to F-3.675=1.0a but what do I do after that? Does the acceleration of the large block have to be zero as well, because if it does then the answer is 3.675 N.
Discussion
well won'tthe accelration of the small block havet to match that of the big one? Wouldn't that mean it is 0 in relation to the big block?
So is the answer 7.105 Newtons then?
Yes they have to be the same. Yes that means it is zero relative to the big block, but the big block is accelerating. You don't know how to do problems in accelerating reference frames. Do the problem in the laboratory frame. Both blocks will be accelerating.
well i found theat the equation for the large block was:
F-Ff-Ff=ma
F-1.96-1.715=1.0a
F-3.675=a
and for the small block:
Ff=ma
1.715=0.5a
a=3.43
then I substituted a into the first equation because they are accelerating at the same rate
F-3.675=3.43
F=7.105 N
woops i forgot to add the 0.5 kg. So it would be 2.94 N instead?
