Solve Guass' Law Q for Ey: Find Electric Field at Point P
  • Thread starter Thread starter k.ingleman
    Guass' law Law
The problem involves calculating the y-component of the electric field at a specific point due to a uniformly charged spherical shell insulator. The insulator has defined inner and outer radii and carries a total charge, with the point of interest located within the shell.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of Gauss' Law and the need to determine charge density. There are attempts to calculate the enclosed charge and volume, along with questions about the appropriate Gaussian surface to use for the problem.
Participants are actively engaging with the problem, exploring the necessary equations and concepts related to Gauss' Law. Some guidance has been provided regarding the choice of Gaussian surface, and there is an ongoing exploration of how to proceed with the calculations.
There is a lack of explicit equations provided in the original post, and participants are working through assumptions about the charge distribution and the geometry of the problem.
k.ingleman
An insulator in the shape of a spherical shell is shown in cross-section at this site: http://kingleman.webs.com/apps/photos/photo?photoid=98095962 . The insulator is defined by an inner radius a = 4 cm and an outer radius b = 6 cm and carries a total charge of Q = + 9 μC (1 μC = 10-6 C). (You may assume that the charge is distributed uniformly throughout the volume of the insulator).
What is Ey, the y-component of the electric field at point P which is located at (x,y) = (0, -5 cm) as shown in the diagram?
Ey =
none
not sure how to get the solution..I know you need to use Gauss' Law
You will also want to get the charge density. You'll want to use Gauss' Law, and some integration (though the integration is easy and not entirely necessary if you know areas and the principles of integration). Give it a try and let us know where you get caught up.
OK, well given that you know that, what do you know about Gauss's Law? Specifically, what's the equation? (It's not "none" :wink:)
I know that qenclosed = ρ*V and so i took qenclosed(9 *10^-6) divided by volume (4/3)*pi*(b^3 - a^3) and got p = .0141...I'm just not sure what to do next..Gauss' Law is integral(E.da) = Qenclosed/8.85×10−12
Think about it like this: Gauss's law is an equation that describes an imaginary surface. It tells you something about the electric field on that surface, based on the charge enclosed inside the surface.
So the first thing you need to do is pick a surface. Which surface would it make sense to use for this problem?
I think you'd use a sphere
Yep, that's right. Now, what is the surface area of a sphere, and how much charge is enclosed within that sphere?
And which sphere? e.g. where is its center? How big is it?
24K
12K
