Solve Limit x→2: (4-(√18-x))/(x-2)
  • Thread starter Thread starter Ritzycat
    Limit
11 replies · 2K views
Ritzycat
[/B]
lim x→2
(4-(√18-x)) / (x-2)
Note that the square root goes over the 18 AND the x, not just the 18.
I don't know how to use the fancy mathematical notation on this forum and I have no idea where to go to find out how to use it.
There are absolutely NO relevant equations. ZERO!
I multiplied the numerator and the denominator by the conjugate of the numerator, because direct substitution would yield an indeterminate. However, after distributing, direct substitution of 2 still gave me an indeterminate.
Here is my distribution
(16-(18-x)) / (4x-x(√18-x)-8+(√18-x))
How can I further simplify this?
Have you learned about L'Hoptial's rule yet?
Ritzycat said:
[/B]
lim x→2
(4-(√18-x)) / (x-2)
Don't FOIL the denominator. Simplify the numerator. You should see a fairly easy cancellation.
No, I haven't!
I think I see what you mean, but doesn't 16-(18-x) simplify to (-2 - x)? My denominator has (x-2) in it.
You didn't distribute the minus sign.
For problems like this, L'Hopital's rule is often ineffective. The approach taken by the OP is the better way to go here.
DUH. Can't believe I forgot to do that. Makes much more sense now.
However, after I simplify and cancel, I'm left with a denominator that = 0 when x = 2.
-1 / (4 - (√18 - x))
After I graphed it, I found there's no limit. (Approaching positive and negative infinity) However, how do I algebraically prove that there is no limit in a function? Sorry for all of these questions - I'm studying limits on my own so I might be missing certain important concepts here and there.
I think you made a mistake. You should end up with 4 + √(18 - x) in the denominator.
Note the parentheses I used to indicate that what's under the radical is 18 - x, not just 18.
I would start with making a replacement [itex]y=x-2[/itex]. You can further simplify this by taking [itex]z=\frac{y}{16}[/itex]. After that just follow the way you did before, but the expression should look much more pleasant now.
Multiply the numerator and denominator by the conjugate of ##4 - \sqrt{18-x}##. From there, it should work out if you simplify everything right.
Never mind, I didn't see that you had already tried that.
