Solve log6(x+6) - log6(x-4) = 3 | Log Subtraction Help
  • Thread starter Thread starter tommy2st
    Log
The equation log6(x+6) - log6(x-4) = 3 can be simplified using logarithmic properties to log6((x+6)/(x-4)) = 3. This leads to the exponential form 6^3 = (x+6)/(x-4). An error occurred when the user mistakenly squared the base instead of cubing it during calculations. After correcting this mistake, the user successfully solved the equation. The discussion highlights the importance of accurately applying logarithmic rules in problem-solving.
tommy2st
2. The attempt at a solution
150/36 is what i get which i simplified to 25/6.
but the program tells me I am wrong can anyone think of how I am getting this wrong
anybody?
I get something close, what steps did you do to get at that answer?
The logarithms (of the same base) are exponents so you can do:
log_6 \frac{x+6}{x-4}=3
6^3 = \frac{x+6}{x-4}
If you made that far, then you should find the rest of the steps.
i figured it out now. i was squaring the base instead of cubing it. thanks for your help tho !
So what did you get?
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
