Solve NPN Transistor Puzzle: -0.4V?
5 replies · 2K views · last reply
I was just sent an email with the following text.
Here is a puzzle I just encountered.
Take any NPN transistor and ground the base. Now apply +12 volts to the emitter through a series resistor of 1k. Yes, it is a Zener diode of about 6 volts so about 6 ma of current flows.What is the voltage between the collector and ground? I couldn't guess. Well I could guess it was zero volts, but then, that would not have been a puzzle. So I gave up.Answer: about -0.4 volts ! (Yes negative.) Why?
""I am at a loss for understanding where they are getting this supposed -0.4V. Any takers?
edit: it is important to note my interpretation of the problem is the the collector is left open
Note that most NPN transistors will be damaged by reverse biasing the E-B junction, especially with such large voltages. I'm not discouraging you from doing the experiment (these things are cheap, after all), but don't expect the transistor to function properly afterward.
meBigGuy said:
Cool problem. Amazing effect.
My thoughts exactly. Thanks for the links everyone. Great reads!
