Solve Shear Stress Problem: Cartilage Deformed at 7.4°
7 replies · 5K views
M_J
The force on a knee cartilage can cause a large force to deform it. The cartilage area is 11cm^2 and the shear modulus is 12MPa. Max force at impact is 904N at an angle of 12 degrees with the cartilage, through what angle (in degrees) will the cartilage be deformed?
http://session.masteringphysics.com/problemAsset/1026529/6/yg.11.35.jpg
Shear modulus = Stress/Strain
Stress = F(perpendicular)/A
Strain = x/h
Stress = 904sin(12)/11x10^-4
Strain = 0.0142
h=11x10-2 ??
angle = tan^-1(0.0142/11x10-2) = 7.4
This method appears a little wrong, is someone able to point out where I have gone wrong and how I should have got to the answer? Thanks! :-)
All units are SI, stress has units of Pa, strain is a ratio so has no units and h is measured in metres. My angle is in degrees.
I would be grateful if you were now able to help me with my answer! :-)
Your angle calculation is incorrect. You already have the shear strain, so why are you dividing by the area?
Chet
Thanks, can you explain what I do need to do then please?
Don't worry, I have done it now - thanks anyway!
SteamKing said:
Your calculations are also units-free, which makes them even more difficult to follow.
Thanks!
what exactly did you do to change your original setup? i can't figure this one out
